Backlit gauges
Discussion in '4 Cylinder' started by dgjones, Jun 23, 2009.
  1. Jun 23, 2009 at 8:27 AM
    dgjones
    dgjones [OP] Well-Known Member
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Ok I have a question about the dash gauges in my 09 Taco. The gauges are always lit up, I can't shut them off...is this normal? I have never had a car with gauges that stayed lit even in daytime.
    Thanks
  2. Jun 23, 2009 at 9:01 AM
    AR_Taco
    AR_Taco Well-Known Member
    Jacksonville Ar
    07 DC 4x4
    3" lift, Flowmaster exhaust, K&N filter, URD short throw shifter, ScangaugeII
    My 07 will only light up after I turn the head lights on, but toyota changed a few things on the 09s so not sure if this is normal.
  3. Jun 23, 2009 at 9:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you have day time running lights the back lights will more than likely stay lit.
  4. Jun 23, 2009 at 9:08 AM
    CVR6
    CVR6 Active Member
    Yes normal. They are lit due to the fact that they are far recessed into the dash, thus under normal daytime driving conditions there is the potential to have difficulty accurately reading them in situations such as dark rainy/snowy days.
  5. Jun 23, 2009 at 9:13 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    mine stay on all the time...i don't think it is tied to the DTRL's because my guages are on before my DTRL's come on.
  6. Jun 23, 2009 at 9:52 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Ok thanks guys, guess it's just something that I'll have to get used to :)
  7. Jun 23, 2009 at 6:58 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    You have tested the dimmer option correct? :confused:
  8. Jun 26, 2009 at 11:26 AM
    dgjones
    Portage, IN
    09 Tacoma Reg Cab
    None yet :)
    Yes I have..I could prob just dim the lights all the way down during the day.
  9. Jun 26, 2009 at 11:37 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    most all newer cars have this feature now...it's so on overcast days or if you drive through a tunnel or something you can still see your guages...maybe some kind of safety thing....has nothing to do with drl which i think are a stupid invention..lol
  10. Jun 26, 2009 at 11:42 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I don't have DTRLs and my guages are always backlit. They dim down when I turn on my headlights, but you can adjust the brightness with the dial to the left of the guage cluster on the dash.
  11. Jun 26, 2009 at 1:01 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I just noticed at lunch that if you turn the dial all of the way down, the lights will go dark.
