Backseat headrests don't fit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gamecocktaco, Feb 5, 2016.
  1. Feb 5, 2016 at 4:05 PM
    gamecocktaco
    gamecocktaco [OP] Member
    Big Dub
    2016 TRD OR Manual
    So when folding down the backseat, you are supposed to take off the head rests and put them in their designated slots on the bench. My headrests do not fit in their slots. Anybody else having this problem? I think Toyota made a mistake with this design.
  2. Feb 5, 2016 at 4:18 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    There's holes in the folded seat for the pegs of the head rests. They work fine for me. I seem to remember they are tight or won't fit is the front seats are too far back. I don't remember for sure, I only did it once to see how it worked.
    They won't fit in the area marked "2" on my truck. If you have JBL, the area behind the passenger side is very small. I don't think that's the intent anyway. Like I said, there's a specific place for them to be inserted.
  3. Feb 5, 2016 at 4:34 PM
    gamecocktaco
    Big Dub
    2016 TRD OR Manual
    I'm talking about the specific holes for the pegs of the headrests. Mine do not fit because the holes are too small. I think It is an old bench seat from the 2nd generation
  4. Feb 5, 2016 at 4:35 PM
    la0d0g
    running for the hills
    For crawling not hauling
    lolz
    0210, TacoJova and T4RFTMFW like this.
  5. Feb 5, 2016 at 4:36 PM
    socal996
    socal996 Well-Known Member
    I was under the same impression, they do fit. 1st make sure you have them facing in the correct direction, then insert one side first slowly push down and it will start to seat, line up the other side and finish install. I put the post nearest the center of the truck in first.
  6. Feb 5, 2016 at 4:42 PM
    gamecocktaco
    Big Dub
    2016 TRD OR Manual
    Thanks for the info, ill have to give this a try.
  7. Feb 5, 2016 at 6:02 PM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    OP if I remember right .... the headrests are turned the other way when inserting them into the folded seat. If you still can't get them in ..... take a pic for us to see
    I don't have many rear passengers; so all 3 of mine are in storage. The headrests take up to much space when I have the seats folded.
  8. Feb 5, 2016 at 6:49 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    first thing i did when i got home, boxed them up and off to storage.....
    MESO and SamChieftan[QUOTED] like this.
  9. Feb 5, 2016 at 7:50 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Op, I had the same issue. Curious if you figure out a solution.
    abjames28 likes this.
  10. Feb 5, 2016 at 9:18 PM
    Shellshock
    Iowa
    As soon as I got home, the headrests came out. I like to be able to see out the back window. I also have my rear seats down about half the time so it's easier to just not have them in the truck.
    Before I took them out, they did fit in the holes. The headrest also do a fold forward thing when fully extended but I'm not really sure what the point of that is.
  11. Feb 5, 2016 at 9:23 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Before I took them out, they did fit in the holes. The headrest also do a fold forward thing when fully extended but I'm not really sure what the point of that is.[/QUOTE]
    They do that so they don't get in the way when you are shoulder checking.
  12. Feb 6, 2016 at 10:32 AM
    gamecocktaco
    Big Dub
    2016 TRD OR Manual
    Doesn't fit. I tried turning it every which way nothing works
  13. Feb 6, 2016 at 11:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Keep trying at it. Maybe the holes need to be slightly stretched using the headrests themselves? Remember it is still a new truck and things are tight.
  14. Feb 6, 2016 at 11:27 AM
    nevadabugle
    Elko, NV
    Same problem I have.
  15. Feb 6, 2016 at 11:56 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Odd. Those locking notches face the other direction on my truck.
  16. Feb 6, 2016 at 12:10 PM
    nevadabugle
    Elko, NV
    hmmm....i wonder if a few of us had them installed backwards? Doesn't seem like that would cause the hole to be smaller though.
  17. Feb 6, 2016 at 12:14 PM
    Shelf Life
    Rob
    Central Oregon
    Unless I'm looking at that picture the wrong way, the notches turn to the inside on mine, but yeah, your right, it should still be able to go in.
  18. Feb 6, 2016 at 12:19 PM
    nevadabugle
    Elko, NV
    Well....I will eat my words. I tried for 15 minute the other day to put the headrests in these slots. I just went out again and tried it and it worked perfectly. Only difference was the first time I tried it was like 5 degrees outside and the truck was cold. Today in the 35 degree range. So, either I am just stupid (highly likely) or the cold was causing the plastic to be stiff and not give around the posts. They were a tight fit today. OP try it in warm weather and put some muscle behind it.
  19. Feb 6, 2016 at 2:00 PM
    gamecocktaco
    Big Dub
    2016 TRD OR Manual
    It was about 50 degrees when I tried it and I tried jamming it into the slot but no luck. Its not that big of a deal I just have OCD when it comes to stuff like that.
  20. Feb 6, 2016 at 2:10 PM
    SamChieftan
    Dallas, Texas
    OP give me an hour or so. I will dig mine out of storage and double check and take some pics.
