backspacing and offset
Discussion in 'Wheels & Tires' started by UpstateTRDTaco, Aug 18, 2011.
  1. Aug 18, 2011 at 5:35 PM
    UpstateTRDTaco
    UpstateTRDTaco [OP] Well-Known Member
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    Where can I find the specs for the backspacing and offset on the stock fake beadlock rims on my TX pro?
    thanks, Josh
  2. Aug 18, 2011 at 5:36 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    On your tapemeasure.
    Honestly, in my experience, that's been the easiest and most reliable source.
  3. Aug 18, 2011 at 5:38 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There should be stamping on the rim that rads something like 16x8jj ET0 or something like that. Post that up and we can tell you the backspacing.
    Measuring also works but it can be a PITA while the rim is still on the truck.
  4. Aug 18, 2011 at 5:44 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Pretty sure those are 4.5" BS
  5. Nov 20, 2011 at 7:15 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I know this is an old thread but I'm wondering the same thing? Also what's the ideal offset/back spacing people typically want?
  6. Nov 20, 2011 at 7:16 PM
    KPT
    09 Prerunner
    Depends what you are trying to accomplish as far as tire size.
  7. Nov 20, 2011 at 7:55 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    What are the determining factors? Fenders, front bumper, cab mount, UCA and spindles? Are there anymore? What is the order in which the tire will hit and what are the typical fixes? Such as if the tire hits the cab mount, would spacers or spindles fix that? I'd really like to get some 295/75 or 305/75/16's on there without chopping the mount...
  8. Nov 20, 2011 at 7:56 PM
    KPT
    09 Prerunner
    That depends on both the height and width of the tire, and the backspacing and width of the wheels. Different combos will hit different things.
  9. Nov 20, 2011 at 8:37 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Gotchya... so it's pretty much, buy the wheel/tires you want and cut away lol... I'm thinking spindles with the TX pro beadlock style wheels and 295/75 or 305/75/16's should be OK? Maybe 1.5" spacers if needed?
  10. Nov 20, 2011 at 8:39 PM
    cummins6speed
    Spacers will make any rubbing you have worse. Those bead lock wheels are 4.5" backspace, if you add that spacer you will essentially have a 3" backspace
  11. Nov 20, 2011 at 8:44 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Thanks for clarifying that.. I kinda thought that might have been the case but wasn't sure... is that the same for spindles as well?
  12. Nov 20, 2011 at 8:47 PM
    cummins6speed
    If those wheels are, in fact, 4.5" BS then they will clear the spindle with a gusset or an after market spindle
  13. Nov 20, 2011 at 9:08 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Awesome! Just hypotheticlly speaking... if the BSing is 4.5 and barely clears the spindles then a wheel with 5.5 BSing would more than likely hit?
  14. Nov 20, 2011 at 9:14 PM
    cummins6speed
    yeah
  15. Dec 7, 2011 at 9:49 PM
    jspetrovitsis
    jspetrovitsis Well-Known Member
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    Toytec/Eibach front coils, Bilsteins on all four, 2 '' AAL, Light Racing UCA, K&N CAI, Weathertecs front and back, Wet Okoles, Alpine INA W900BT in dash navigation, LED cab lights
    I have the 2011 tx pro wheels and am trying to put 285 75 16s under it, will it rub against any suspension parts like the UCA or anything. I am putting in the 3'' toytech lift with 2'' aal in the back.
  16. Dec 8, 2011 at 5:39 AM
    KPT
    09 Prerunner
    You should be alright for UCA clearance.
  17. Dec 8, 2011 at 9:38 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    how about any other rubbing issues? I am ok with trimming the wheel well but I am not trying to trim or remove any of the fender flares
  18. Dec 9, 2011 at 7:49 AM
    KPT
    09 Prerunner
    You won't have to trim the flares but you may have to chop your cab mounts.
