Backspacing Concerns
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dustin03, Sep 7, 2008.
  1. Sep 7, 2008 at 9:49 AM
    Dustin03
    Dustin03 [OP] The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    I'll soon be in the market for some new tires and wheels, so I'm doing the preliminary research on my options. I've got an '03 with the 2.5" OME lift kit and I'm looking to move up to 33x10.50R15 BFG All-Terrains. My concern is that I've just gotten the stock tires to stop rubbing with the new lift kit, and I'd hate to have that problem again with the increase in tire diameter.
    So here are my questions: When I buy the new wheels do I order them with a little more backspacing to push the wheels out a bit farther? Is it wise to mess with such things as far as the longevity of the CV joints? And lastly, are there any other concerns that I may want to consider before making this decision?
    P.S. I suppose this thread should technically be in another part of the forum, but upon realizing the vast majority of members outside this division are Gen 2 owners, I hoped you all might be better suited to answering this question.
  2. Sep 7, 2008 at 10:09 AM
    RealSouthernPride
    RealSouthernPride Well-Known Member
  3. Sep 13, 2008 at 8:21 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    with 33s and 2.5" lift, you will likely still get some rub at full articulation...
    im running 285-75-16 Cooper STT's on 3" coilover lift with fiberglass fenders and still get some rub at full lock and articulation...
    your tolerance for that is subjective, but it can be done...
    as for the backspace, with that big a tire, you will want to stick to a 4" or 3.75" backspace to keep the tire away from the UCA, however the 2.5" lift may not keep them far enough away from the pinch weld or stock fenders...
    what helps is during alignment, is to request the technician to keep your caster at 1.5 to 2 degrees forward...
    good luck...
  4. Sep 14, 2008 at 12:54 AM
    Dustin03
    Arizona
    Thanks for the advice, man. Now I have some notion of my options.
  5. Sep 14, 2008 at 12:56 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    toy4life has 33x10.50 bfgs on 15x8 cragar 397's with 4" backspacing...and they look like they fit spot on
  6. Sep 14, 2008 at 10:30 PM
    Dustin03
    Arizona
    This may seem like a stupid question, but when we're talking about 4" versus 3.75" we're talking about a DECREASE in backspacing, meaning the wheels are pushed in toward the centerline of the car, right?
  7. Sep 15, 2008 at 11:36 PM
    350TacoZilla
    Hancock MD
    right 3.75 backspacing would sit each wheel out .25 farther making truck's track .50 wider over all when compared to 4" backspacing.. not bad to a point but once you get the tires too far from the center line of the knuckle they pivot on you get tire scrub,wheel bearing wear and a bigger turning radius
  8. Sep 16, 2008 at 1:43 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Dustin, I'm running (like Zilla said)33/10.5/15 bfgs on 15x8 Cragar's. The tires are nowhere near the UCAs and only rubbed the front mudflaps and the plastic over the pinch weld. The wheels I got required 1/4" spacers up front to clear the brake calipers. Your brake calipers will be your biggest issue.
  9. Sep 16, 2008 at 10:17 PM
    Dustin03
    Arizona
    So you have pretty much exactly the same setup I want to run. Sounds like I should order the wheels with 3.75" or 3.5" backspacing. Will that work or is the caliper clearance issue as such that the spacer is the only way to go?
  10. Sep 17, 2008 at 10:52 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    It depends on the wheel. Different back spacing might address caliper clearance, but I'm not sure. In PA, where I live, vehicles need annual inspections and the tires/wheels cannot stick out past the fender. I had to be very cautious about the wheels to be sure that wouldn't be a problem. Check out .
    The wheels they sell are reasonably priced and spacers aren't necessary.
  11. Sep 17, 2008 at 12:24 PM
    350TacoZilla
    Hancock MD
    actually backspacing wont get the wheel hub surface any farther away from caliper face... no matter what spacing you go with the wheel center bolts directly to the hub surface on rotor... only way to change is to add a spacer like toy4life or grind off the ridge on front of calipers (easy IMHO)... but also different wheels may or may not fit without spacers... I have 15x8.5 old school american racing AR-23's and somehow due to their design they fit...no spacers...its like the wheel spokes lean forward enough to clear caliper...where a flat center wheel would hit....make sense? I hope so lol
  12. Sep 17, 2008 at 12:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for wheels that should be a direct fit......check wheelers and look at the wheels they have.....may be just what you are looking for.:)
  13. Sep 18, 2008 at 9:05 PM
    Dustin03
    Arizona
    Hmm... Well I appreciate all the advice; it'll definitely come in handy. I think I'm going with 16x8 Cragars with the typical 4" backspacing. I'll just have to make sure I like the way it works out before I mount the tires. Summit Racing is really good about taking returns as long as nothing is damaged.
  14. Sep 18, 2008 at 9:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what are their prices on those wheels?? just asking because the 15x8 steelies that wheelers has, with 4 inches back spacing, are really a reasonable price, and they are guaranteed to fit.
  15. Sep 18, 2008 at 9:14 PM
    Dustin03
    Arizona
  16. Sep 18, 2008 at 9:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  17. Sep 18, 2008 at 9:26 PM
    Dustin03
    Arizona
    That is sweet site. More food for thought... I never would have imagined picking wheels would be this difficult. :laugh:
  18. Sep 18, 2008 at 9:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it can be a fun filled,hair pulling adventure!!!:D wheelers is awesome tho........and jason perry, one of the salesman there is an awesome dude to do business with!!
  19. Sep 19, 2008 at 10:59 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I was in the same boat as you 6 months ago. Finding the right wheels can be a real bitch, but once you finally get them, it's all worthwhile. The guys at Wheelers are definately good. The only reason I got the Cragars over the Wheelers, was I could drive to Summit for the Cragars. To ship wheels from Oregon to PA was going to cost me significantly and would've destroyed the budget I was working with. Here's my truck with 15" Cragars.
  20. Sep 19, 2008 at 8:40 PM
    Dustin03
    Arizona
    God that looks good! :drool:
    I gotta say I like the looks of the Cragars more with the eight stampings over the seven. I'm still building the budget right now though, so I have a bit of time yet to torture myself over the final decision. :rant:
