Backspacing help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MDBigRed, Oct 24, 2009.
  1. Oct 24, 2009 at 8:15 PM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    OK so i have the 4" RCD lift on my truck and i'm currently running 17x9 moto metals with a 4.53 backspacing with 285-70-17 BFG AT's. They work with no issue. I'm looking at getting 16x8 Procomp rock crawler series 52 steelies with 285-75-16 MT baja claws. On the RCD install sheet it says "with a maximum backspacing of 4.5". should i get the steel wheels with 2.5, 4, 4.25, or 4.5 backspacing?? will the tires stick out farther with 2.5 vs 4.5? thanks :)
  2. Oct 24, 2009 at 8:41 PM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    smaller the number the more the tire sticks out i believe.
