Backspacing, Negative Offset, etc.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dmillersmfd, Aug 26, 2015.
  1. Aug 26, 2015 at 10:19 AM
    Dmillersmfd
    Dmillersmfd [OP] Member
    Dustin
    2004 Tacoma
    I currently have a 2004 Tacoma, everything stock. I am about to put on the OME 882 with full leaf set change out. I am also looking to step down from a 16" wheel to 15" steel wheels and want to run 33 x 15 x 10.50. What I can't seem to grasp is what back spacing, negative offset, etc. I need to have to minimize if not eliminate rubbing. Any recommendations?
  2. Aug 26, 2015 at 9:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    First off, with 33's there will be rubbing. No wheel package alone will fix that.
    If you run a 15x8 wheel, you need 4.5" of backspacing or less. On an 8" wide wheel, 4.5" of BS is equal to 0 mm of offset. Any more than 4.5" of BS may cause the tire to not clear the upper part of the spindle/ball joint area and it will definitely cause rubbing on the frame when you turn.
    I am running 33x10.5/15s on 8" wide steelies with 3.75" of BS. This is -19 mm of offset on an 8" wheel. The less BS you have, the more it moves the tire outboard away from the frame rub when turning. However, you will still have to clearance the pinch weld (behind the mudflap) area. There is no avoiding this with 33s.
    Does your Tacoma have the factory big brake package? Some '04 models came equipped that way. If so, you will not be able to run a 15" wheel. The big brakes will interfere.
  3. Aug 26, 2015 at 9:43 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    4" BS is what I'm running. Slight rub on the frame in the front at full lock. BFH to the pinch weld was a must.
    I think many people (like Mike) have had good experience with the 3.75" BS but the pinch weld mod is still required.
    Digiratus likes this.
  4. Aug 27, 2015 at 2:01 PM
    Dmillersmfd
    Dustin
    2004 Tacoma
    Fortunately, I don't have the big brake system. Would you recommend going with a different wheel/tire sizing or have you had pretty good luck overall with 33's?
  5. Aug 27, 2015 at 2:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Do you have the manual trans or is it an auto? v6?
    IMO, 33x10.5/15s with a regear to 4.88s is perfect on my auto. Stock gearing with the 5-speed and 33s is a little more tolerable but still not ideal.
  6. Aug 27, 2015 at 2:33 PM
    Dmillersmfd
    Dustin
    2004 Tacoma
    Manual. V6
  7. Aug 27, 2015 at 2:36 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    anything less than a 4 inch back space will stick way out and be hell on your wheel bearings, try to stay in the 4.5-4 range with most likely a -6 or -12 offset.
    Unless you're going for the Hawaiian look brah.
  8. Aug 27, 2015 at 2:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The first half of your comment is valid and has good info.
    However, I don't understand why you feel the need to add the slanderous second half.
  9. Aug 27, 2015 at 2:57 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    its a style in hawaii to have your wheels and tires stick out like 8 inches............ whats slanderous? :rofl:
  10. Aug 27, 2015 at 3:06 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Whatever butters your biscuits. :thumbsup:
    [​IMG] [​IMG] [​IMG]
  11. Aug 27, 2015 at 4:42 PM
    tomtom
    The Desert SW
    2012 FJ
    Most of the "stick way out" is due to 10" and 12" wide rims. A 3.75" BS on an 8 inch rim will stick out .25" more than a 4" BS on the same width.
    An FYI, here's a nice article that summarizes calculating offset from BS and vice-versa.
    http://thesquealingtire.com/wheel-offset-and-backspace-explained/
  12. Aug 27, 2015 at 4:50 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
  13. Aug 28, 2015 at 7:01 AM
    Dmillersmfd
    Dustin
    2004 Tacoma
    What tires are you running? I'm leaning towards BFG KM2's.
  14. Aug 28, 2015 at 7:05 AM
    Dmillersmfd
    Dustin
    2004 Tacoma
    Also, I'm 99% sure I don't have the large brake system that I guess they put on some of the '04s. But is there a way to verify that?
  15. Aug 28, 2015 at 9:47 AM
    Digiratus
    Roaming the PNW
    The RedHead
    KM2s
    I've seen threads on here but ATM I can't link you to them. Do some seaches in the 1st gen section or the Tacoma Garage.
