Backspacing of Stock Steelies (6 Lug)?
Discussion in 'Wheels & Tires' started by 90YotaPU, Nov 4, 2011.
  1. Nov 4, 2011 at 4:39 PM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Does anyone know the backspacing of the stock steel 6 lug wheels? I'm thinking about ordering some Wheeler's black steelies but don't know to go with the A (4") or B (4.5") ones. If the stock wheels are 4" than I may get the A's and use my Spidertrax spacers. If they're 4.5" then I'll get the B's and definitely use the spacers.
    Thanks.
  2. Nov 4, 2011 at 4:47 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    What is your goal for these rims 33" tires? Desired backspacing is 4.5" stock bs for our trucks is 5.5"
  3. Nov 4, 2011 at 4:50 PM
    90YotaPU
    Union County, NJ
    Thanks for the prompt reply. I am running 265/75r16's (basically 32's) and plan to stick with them so I don't overweight the 4 banger. I just put an AAL on the back and cranked up the 5100's to 2.5 so I'm trying to get the wider stance than stock. I had the stock steelies with the Spidertrax and loved the look.
  4. Nov 4, 2011 at 4:54 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Pretty sure the weight won't bother that stout little engine.
