backspacing ?
Discussion in 'Wheels & Tires' started by 91Toyotabogger, May 2, 2010.
  1. May 2, 2010 at 7:23 PM
    91Toyotabogger
    91Toyotabogger [OP] "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    I know this has been asked before im sure hundreds of time but, if im running a 91 Toyota pickup 4x4 no lift and stock or close to stock wheels what backspacing do i need, i have 31x10.50xr15 now but im thinking about going to a 32x11.50xr15 what do i need to choose?
  2. May 2, 2010 at 7:24 PM
    91Toyotabogger
    North Carolina
    i like the mickey Thompson classic II here's the info
    • M/T Classic II Wheel
    • 15x8, 6 on 5.5 Bolt Pattern
    • BackSpace 3 5/16 in.
    • Max Load= 2000lbs
    • Finish = Polished
    • Hubcentric= No
    • Offset = -30 mm
    Will it fit? please help
  3. May 2, 2010 at 7:29 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    stock should be 4.5"
    those wheels will stick out quite a bit...
  4. May 2, 2010 at 7:31 PM
    91Toyotabogger
    North Carolina
    so the backspacing should be 4.5 and what about offset? so the smaller number backspacing the more the wheel will stick out?
  5. May 2, 2010 at 7:34 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yep smaller backspace sticks out more
  6. May 2, 2010 at 7:34 PM
    91Toyotabogger
    North Carolina
    and offset?
  7. May 2, 2010 at 7:52 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    not sure about what offset you would need...
    with our trucks, backspace is what you need to clear calipers and keep the tires from rubbing, etc...
    i once found a graphic that explained offset and backspace on google... too lazy to look for it again...
  8. May 2, 2010 at 8:10 PM
    91Toyotabogger
    North Carolina
    yeah i found where a site was saying like 3 3/8 bs my rims are wide deeper in the back than the front now, but back spacing is how deep the rim goes back behind the plate where it touches the axle
