Backup camera ideas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kevins60, Jan 2, 2020.
  1. Jan 2, 2020 at 2:48 PM
    Kevins60
    Kevins60 [OP] axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    Looking to upgrade the headunit and add a backup camera. I think I could mount this https://www.amazon.com/dp/B07H852D4...olid=3MSBFOZO44289&psc=1&ref_=lv_ov_lig_dp_it
    Next to the tailgate handle like a 2nd or 3rd gen. It looks like it should just fit and hopefully look like part of the black plastic handle itself. Not sure how I’m going to route the wire from the tailgate. I see there are drain holes but I’m wondering about wire getting pinched or chafing. I’ve seen pics of cameras on the tailgate on the forum but no description of how they routed he cable. Any thoughts?
  2. Jan 3, 2020 at 8:31 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you are worried about chaffing where a wire runs through a hole (and you are right to be worried), you could look for a rubber grommet of the right size, put it into the hole, and then run the wire thru that. If the hole is not round, you might want to use some split flex tubing around the wire.
  3. Jan 3, 2020 at 9:11 AM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    If I were to install one of these, I’d probably run thee wire under the bed and then into the cab through a hole in the floor (maybe O2 sensor wire) or up to the engine bay and through the firewall if there were enough wire.
  4. Jan 3, 2020 at 12:18 PM
    Kevins60
    Kevin
    Odessa FL
    I’ll take a walk up the block to see how the neighbor’s 3rd gen is run to get some ideas.
  5. Jan 3, 2020 at 12:29 PM
    Kevins60
    Kevin
    Odessa FL
    I figured I would run the cable up one of the frame rails cables tied to the run for the brake lights. I’ll need to find where the backup lights get their power or pull the console apart to see if I can pick up +12v for the backup lights there. If that pans out then it should be fairly simple to sneak the video cable along the floor and up under the dash. The trick for me is going to be getting the cable from the tailgate to somewhere under the truck.
  6. Jan 3, 2020 at 2:18 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    If you're talking about mounting it to the black plastic, you will have a hard time finding the space. I thought about using one of those cameras with the stud, but the nut for mounting the handle is right where you want to mount it. Pull off your tailgate handle and you will see what I'm talking about.
    Someone on here actually removed/drilled out the nut on the handle and then used the stud on the camera to mount that side. If you go this route I believe you will need to widen the hole in the tailgate as well. Also, you won't be able to aim the camera unless you get one that can move independently from the mount.
  7. Jan 3, 2020 at 2:37 PM
    Kevins60
    Kevin
    Odessa FL
    That was exactly what I had in mind. I won’t know if I have to widen the hole or drill a new one until I have the camera in hand. I don’t think the nipple on the back of the camera will interfere with the rods inside the tailgate but I’ll be sure before I start blasting holes in sheet metal.
  8. Mar 11, 2020 at 2:31 PM
    Kevins60
    Kevin
    Odessa FL
    A couple minutes with a 5/16 drill bit and it worked perfectly.DC2B4048-3190-485F-8E4E-0A6DB80E8623.jpg
    took me a while to get moving on this but Amazon had the HU I wanted for $50 off because the box was dented. That was all the motivation I needed. Used a grommet in a drain hole and flexible sheathing to go between the tailgate and under the bed
    tacoma_ca likes this.
  9. Mar 11, 2020 at 4:36 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    What camera is it? Can you show a close-up picture of the mounting and the picture of the image shown on head unit? Please.
  10. Mar 11, 2020 at 6:56 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
  11. Mar 11, 2020 at 7:02 PM
    wourkrsd
    wourkrsd Well-Known Member
    Komifornia
    2000 SR5/TRD 3.4 4x4 5 Spd. Ext Cab
  12. Mar 12, 2020 at 4:12 PM
    Kevins60
    Kevin
    Odessa FL
    @RysiuM its he camera I posted earlier in this thread https://www.amazon.com/dp/B07H852D4...olid=3MSBFOZO44289&psc=1&ref_=lv_ov_lig_dp_it
    I still need to adjust this, ideally the red line would be on the back edge of the bumper. The camera came with tapered grommets to do that, I just haven’t gotten around to it
    tacoma_ca and RysiuM like this.
  13. Mar 12, 2020 at 4:19 PM
    Kevins60
    Kevin
    Odessa FL
    My goal was to stop backing into things. I can’t see the bumper in your camera
  14. Mar 12, 2020 at 4:26 PM
    RysiuM
    Rysiu
    Bummer, Amazon does not ship it to Poland. Crap. I really like the image on your DD especially that you can see both corners of the rear bumper. This is what I was looking for. I guess I need to utilize my friends in USA to ship me this camera. Thanks a lot for the info.
  15. Mar 12, 2020 at 4:53 PM
    nzbrock
    Noah
    San Marcos, TX
    I did a lot of research on cameras with super wide angle lenses. It is very difficult to find the actual angle of view because so many of them exaggerate it.
    I got this camera https://smile.amazon.com/gp/product/B07R7ZG243/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    and it does have a SUPER wide view. I currently have it mounted on my topper rack, and I can see a whole street behind me including my bumper.
    It's great for backing out of parking spaces in a lot.
    I'm going to experiment with putting it just below the topper window handle to get a better view of the bumper.
    Also, I bought it for $60 a year ago, so that current price is a steal.
    jonesbt and tacoma_ca like this.
  16. Mar 12, 2020 at 5:11 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'm planning to fit a stud-mounted camera to a small hole drilled on the left side of my Pop'n'Lock. Looks good mounted in the lock hole, though.
    mattlang and jdmstuff[QUOTED] like this.
  17. Mar 12, 2020 at 6:22 PM
    beez
    beez Well-Known Member
    Nate
    04 single cab PreRunner
    I have one of these:
    I am going to install it just to the left of the tail gate handle, at the same height.
    This is so it won't be blocked by my hitch mounted bike holder.
    I am going to use a rear view mirror monitor thingy, if I can figure out how to get the metal mounting puck glued to my windshield.
    I think mine has a very light tint on the inside, so the glass glue doesn't work.
  18. Mar 12, 2020 at 7:09 PM
    jdmstuff
    Derrick
    I could have angled it more, but where the red lines are, I have about 12" before hitting the bumper. I'm good with that. I needed it more to see what's coming around the sides. My cap blocks a lot of my view from behind.
  19. Mar 13, 2020 at 1:36 AM
    7acoma
    7acoma Active Member
    96 Ext Cab White Tacoma
  20. Mar 13, 2020 at 6:24 AM
    4xdog
    Santa Fe, NM
    Here's a late model Hilux (at a company up-armoring them for our Uncle). Note the camera mounted on the tailgate panel itself for those with courage enough to drill into it.
    Click on the image for full-size view.
    chrslefty likes this.
