Backup Camera in Mirror AND Nav
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uber27, May 13, 2012.
  1. Jan 16, 2013 at 1:14 PM
    #81
    Daddy4zack
    Daddy4zack Active Member
    Aaron
    El Dorado Hills
    2013 TRD
  2. Jan 16, 2013 at 1:48 PM
    #82
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    I have a 2012 and mine shows up on nav screen only. My goal is to wire it so i can flip on the one in the mirror anytime, even while driving.
  3. Jan 25, 2013 at 11:29 PM
    #83
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    My brother in law has a 2013 with the JBL Entune and his shows up on the mirror. He wants it on the HU
  4. Jan 26, 2013 at 12:40 AM
    #84
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    I test drove a '12 TRD Off Road before I bought the '13 TRD Off Road. The '12 had the display on the entune and the '13 has it on the mirror. I thought that it would have been on the entune but NO. I would like a choice although it works great in the mirror.
  5. Jan 26, 2013 at 1:13 AM
    #85
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I do not mind it on the screen, but my brother in law hates it on the mirror. Do not know why it switched from the 12 to the 13 like that
  6. Jan 26, 2013 at 1:50 AM
    #86
    rubenc87
    rubenc87 Cobra
    Texas
    2025 Tacoma TRD PRO
    As another member posted, if we can figure out the pattern and what is involved to switch from one to the other , that would be great.
  7. Jan 26, 2013 at 6:35 AM
    #87
    Daddy4zack
    Aaron
    El Dorado Hills
    2013 TRD
    im going in for an oil change today.. im going to ask.. i hate it on the mirror..
  8. Mar 9, 2013 at 8:04 PM
    #88
    OmegaQuest
    OmegaQuest Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    * Bump *
    I have the 2013 Limited with the Entune/NAV/JBL and I would love for the backup camera to be viewable on my Headunit like my 2011 Taco did (Aftermarket HU).
    Thanks
  9. Apr 8, 2013 at 6:19 PM
    #89
    nimrod1
    nimrod1 Member
    So I have done some work on this concept on a 2013 Limited and on a 2013 SR5. The Limited had a factory backup cam with the display in the rearview mirror and the SR5 did not come with a cam. Both trucks had the basic display audio radios. On the SR5 I was able to add an OEM Backup cam to the tailgate and plug it into the existing connector under the passenger side of the bumper. (Most of the Tacos I have come across are pre-wired) I then was able to grab the backup cam wiring harness at the other end right in front of the fuse box left of the steering column and splice into it there so I did not have to run the wires front from the back of the truck to the front.....it gets tricky here.....the stock display audio radio does not have the video input harness connector from the factory so you have to try and obtain one from a donor vehicle in order for this to work. I took the backup cam wires and built a jumper harness from it to the radio, used a connector that I was able to acquire, and now have a backup image on the stock radio. On the limited I was able to take the existing backup camera system and modify the same connectors to display the image at the radio, the rear view mirror, or both. Furthermore I can add a switch if I want to which will allow me to turn the camera display on or off at will. I am in the process of locating the empty connectors and pins so that I can build these adaptors and provide them to the marketplace. Hit me with questions and If I can answer them I will
  10. Apr 8, 2013 at 7:26 PM
    #90
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    I want! Does this work with the entune system? I have entune and i pt displays on radioo, but i want image on either screen I choose and at will with a switch.
  11. Apr 8, 2013 at 7:32 PM
    #91
    tmreyes1
    T-Rey
    TX
    2017 TRD
    I like it on the screen but would like to install a switch
  12. Apr 8, 2013 at 7:35 PM
    #92
    OmegaQuest
    Maryland
    I would be interested in the version for the 2013 Limited with Entune and JBL
  13. Apr 8, 2013 at 7:38 PM
    #93
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    I'm in for the camera display kit for the nav screen.
  14. Apr 9, 2013 at 6:53 AM
    #94
    Bk12
    Bk12 Member
    2013 Tacoma Prerunner Double Cab
    My 2013 did not come with a camera, but it was factory pre-wired, so I purchased a rear view mirror with a display in it, rear camera, and it was just plug and play. Now I'm trying to show the image on the touch screen radio display, like you mentioned. My question is which wires/pins at the back of the radio should i connect the two video wires that go to the rear view mirror. Do I need to connect the power to the radio, or not because its already powered up.
  15. Apr 9, 2013 at 6:54 AM
    #95
    Bk12
    Bk12 Member
  16. Apr 9, 2013 at 2:33 PM
    #96
    nimrod1
    nimrod1 Member
    As long as your rear view mirror has a monitor in it then yes you can setup a switch to view it on either screen....it is not quite as simple as adding pins to a connector because the connector is not present at the back of the radio....only the socket for the connector is. You will need the connector and the pins that go in it for this to work
  17. Apr 9, 2013 at 2:45 PM
    #97
    nimrod1
    nimrod1 Member
    Wow I got quite a few replies to my posting about this backup cam mod so Im trying to provide as much info on the thread as I can. I am still working through all of the different Tacoma models to figure out what limits if any there are with the modification. Obviously if you want to view the cam from both the rear view mirror and the radio then you will have to have both the rear view monitor mirror and the display audio radio. Then you will also need the connector housings, pins and wiring, switches if you want to go from screen to screen and of course all of the information to do the job. I have already sourced the connector and the pins that go to the back of the radio and now I am working on obtaining the connector and pins that plug into the junction in front of the fuse box where the camera and the rear view mirror wiring are located. This will eliminate the need to cut any wiring and will simply "T" in instead. So far it does not seem to matter if the Truck is equipped with JBL, Entune, or just the standard radio the wiring and process seems to be the same
  18. Apr 10, 2013 at 1:39 PM
    #98
    Jt526
    Jt526 Member
    Count me in for one, preferably with a stock looking switch or something to do HU/Mirror/Both.
  19. Apr 11, 2013 at 5:45 PM
    #99
    nimrod1
    nimrod1 Member
    I am looking for a cool switch to complete the modification for the back up cam....It appears that many of you would like to be able to switch from one screen to the other. Once I have compiled all of the parts I will build a prototype with a switch and tee harnesses to see if it truly can be plug and play.
  20. Apr 11, 2013 at 5:55 PM
    #100
    jaymay82
    jaymay82 Well-Known Member
    '13 MGM TRD Sport DCSB
    any updates?
