Backup camera install w/o wiring harness
Discussion in 'Audio & Video' started by mikecain, May 25, 2011.
  1. May 25, 2011 at 12:55 PM
    mikecain
    mikecain [OP] Well-Known Member
    Morro Bay, CA
    06 PreRunner Trd-offroad
    If I were to have an OEM backup camera and mirror display, would it be possible to wire it up without the wiring harness? Has anyone done this on a 08- tacoma without the harness?
    Any help would be appreciated!
    Thanks
  2. May 25, 2011 at 5:30 PM
    mikecain
    Morro Bay, CA
    bump, is the wiring harness necessary?
  3. May 25, 2011 at 5:44 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    It's not wireless, so I would assume the harness is necessary.
    If you have access to the connectors and are willing to run wires, then certainly it can be done without the harness. Probably wouldn't hurt to have the wiring diagrams so you can tell which wire goes where.
  4. May 25, 2011 at 5:47 PM
    mikecain
    Morro Bay, CA
    the connectors are exposed, but I was just trying to figure out how I would connect the pins to the wire without the harness plug.
  5. May 25, 2011 at 5:50 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    You need the plugs. Mine is all aftermarket to the head unit, so no need to buy the Toyota stuff. I bought a pop and lock and modified it to accept a cheap ebay camera i found.
  6. May 25, 2011 at 5:55 PM
    mikecain
    Morro Bay, CA
    kinda confusing.. I would assume that with some cat-5 cable and the wires on the correct pins that it would work without the oem plug. I'm just interested to see if anyone has done this. And in some cases that I've seen, other members have had the harness, but it just goes as far as the spare tire then they ran wire from there to the cab. So I would think it would work without it. right?
  7. May 25, 2011 at 5:57 PM
    rcbs204
    Oh it will work, you just got to figure out the pinout on the camera and the mirror.
  8. May 25, 2011 at 6:06 PM
    mikecain
    Morro Bay, CA
    Ive seen a callout for all the wire color values. Does anyone have a picture or a schematic of which pin goes to which wire color?
  9. May 26, 2011 at 1:04 PM
    mikecain
    Morro Bay, CA
    bump, for someone who has done this?
  10. May 26, 2011 at 3:56 PM
    06ToyTaco
    06ToyTaco Well-Known Member
    CA
    06 4x4 DCLB Sr5 Silver
    OME 885X, 1.5" AAL + TSB, LR UCA
  11. May 29, 2011 at 5:47 AM
    jbboater
    jbboater Member
    I gave up searching and shelled out the $15 for access to the diagrams for two days. I have a DNX-7140 attached to a cheap camera in my 07. I got a stock camera and a pop and lock handle. Anyway the information is in the PDF. It should be fairly straightforward now since I know what wire goes to what pin on the tailgate. I'm hoping to pick up some sort of connector at RS to allow me to slip each wire over the pin on the camera.
  12. May 29, 2011 at 9:23 AM
    mikecain
    Morro Bay, CA
    Derrick, I've seen that thread he has a harness for the install but it was also very helpful. Jbboater, thank you! That is exactly what I've been searching for. This should be very easy with that diagram.
  13. Jun 10, 2011 at 1:26 AM
    vietboytoan
    vietboytoan Member
    Phillip
    Houston, TX,
    07 PreRunner SR5 2WD Tow Package
    In Progress...
    I actually just installed my back up camera two weeks ago with out the harness on my 07 double cab. I installed a aftermarket head unit and bought the tailgate handle off ebay and got some cat-5 cable made to be ran underwater, so very well weatherproofed. I work on electronics, as I am a Electronics Technician in the Navy, and got some pin extenders that slided on the pins in the camera very snug, soldered those. From there, I ran the cat-5 cable and took the reverse lights power to the camera and soldered all the connectors. I have all the pins if you still need them. It worked out really well and havent had any problems yet.
  14. Dec 14, 2011 at 4:39 PM
    Tacogrande05
    Tacogrande05 Member
    Rich
    Pennsylvania
    05 SR5 TRD
    has anyone ever installed the OEM backup camera/rear view mirror that comes with the post '09? I would really like to install this on my '05 taco
  15. Dec 14, 2011 at 5:57 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    me! lol
  16. Dec 14, 2011 at 6:45 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
  17. Dec 15, 2011 at 4:45 AM
    Tacogrande05
    Tacogrande05 Member
    Rich
    Pennsylvania
    05 SR5 TRD
    thanks Muisejt, I was also looking at a head unit, the ANI-W910, I'm not sure I like the camera they have with it though, would prefer the pop lock tailgate one, is this the one you used with your head unit?
