Backup camera install
Discussion in 'Audio & Video' started by baldy54, Nov 25, 2012.
  1. Nov 25, 2012 at 9:17 PM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Hello I have a 06 tacoma and i am installing a backup camera. I have the camera mounted and wired.. But I have one question.. I cant find where to hook up the back up sensor wire from the kenwood dnx8120 to tell the hu turn on the view from the camera.. I would not like to tap into a factory wire if I can help it.. I rather us the wire harness instead to make my connection.. Please help..
  2. Nov 25, 2012 at 9:25 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    another thread???? why? PM a mod to delete your other one at least...
  3. Nov 25, 2012 at 9:28 PM
    baldy54
    Orlando, FL
    06 Prerunner SR5
    ok sorry I am new.. And wanted to solve this problem.. I thought if I posted on both I get someone to reply..
  4. Nov 26, 2012 at 7:51 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    columbia, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    maybe this will help.. you will have to run a wire and tap into this but its easier then going all the way to the light...
  5. Jan 13, 2013 at 7:49 AM
    Toyotaco1670
    Toyotaco1670 Active Member
    Florida
    2017 Tacoma Doublecab SR5
    I looked at mine and I don't have that red wire with a white stripe.
  6. Jan 16, 2013 at 9:27 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    do you have a way to test power?
  7. Jan 16, 2013 at 8:57 PM
    Toyotaco1670
    Florida
    I have a multimeter but not sure which setting to put it on.
  8. Jan 16, 2013 at 9:01 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Set the DMV to 12 volts DC. If the multimeter is not multi ranging, set the dial to 20 volts or less.
    Red test lead is positive and the black lead is negative on your meter.
