Backup camera install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Nov 25, 2012.
  1. Nov 25, 2012 at 9:19 PM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Hello I have a 06 tacoma and i am installing a backup camera. I have the camera mounted and wired.. But I have one question.. I cant find where to hook up the back up sensor wire from the kenwood dnx8120 to tell the hu turn on the view from the camera.. I would not like to tap into a factory wire if I can help it.. I rather us the wire harness instead to make my connection.. Please help..
  2. Nov 25, 2012 at 9:22 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    you must have to tap into the shifter wiring of the truck somehow, thats the only way i could see getting the signal that youre in reverse and it needs to show up....
  3. Nov 25, 2012 at 9:37 PM
    baldy54
    Orlando, FL
    06 Prerunner SR5
    thanks for the help..
  4. Nov 25, 2012 at 10:00 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    You need two power sources, one simply powers up the camera, I just speed-sliced the hot leg of my reverse light on one side. That way I used very little wire. The other needs to needs to "tell/signal" the HU to switch to the back up camera mode. Behind your driver side kick panel, you'll see a red and white wire, this needs taped into thehead units reverse wire. On a Pioneer unit the wire is purple/white stripe, not certain on a Kenwood.
