Backup Camera not coming up in reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Snakedoctor, Aug 25, 2019.
  1. Aug 25, 2019 at 4:06 PM
    Snakedoctor
    Snakedoctor [OP] Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
    I’ve got the anytime backup camera mod and lately I’ve noticed sometimes in reverse the backup camera doesn’t display on the radio. It’s a plug in kit so I didn’t mess with any factory wires for it. I did it after about a month or so and I have no clue if this is part of the trucks issue or maybe the anytime backup camera. If I cycle through gears a few times the camera will pop up.
    Anyone else have an issue like this?
  2. Aug 25, 2019 at 4:11 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Have you tried to remove the mod and see if it works every time?
  3. Aug 25, 2019 at 4:17 PM
    Shellshock
    Iowa
    I’d try removing the mod and seeing it if works.
  4. Aug 25, 2019 at 4:24 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    I can’t get it to do it is the problem. It just does it randomly. I’ve gone months with no issue then one day it’ll happen a few times and then back to normal use. So far I’ve found no rhyme or reason and am unable to replicate the issue.
  5. Aug 25, 2019 at 4:26 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Look at you connection to the rear cam. I believe its an rca cable. Next is see if there is power to the cam
  6. Aug 25, 2019 at 5:17 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Kinda hard to check since after I put it park and then change it the camera will come back on. I know the light on my switch always comes on.
  7. Aug 25, 2019 at 6:16 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    I’ve tried it both ways. I can’t recreate the problem to see narrow down the issue. It seems like it’s just the head unit acting out because the switch light acts up showing the camera is active just doesn’t show up.
    A few days ago my head unit reset itself a few times while trying to put a call on BT.
  8. Aug 25, 2019 at 6:30 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Can you recall if you ever disconnected the negative battery cable for whatever reason and the problem with camera started after that?
  9. Aug 25, 2019 at 6:33 PM
    Shellshock
    Iowa
    Have you ever updated the software on your head unit? The newer software fixes the Bluetooth crashes
    Is your truck manual or automatic?
  10. Aug 25, 2019 at 6:43 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Might have something to do with the shift position sensor and nothing at all to do with the mod.
    Shellshock likes this.
  11. Aug 25, 2019 at 7:13 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    I have updated it but now that you’ve mentioned it that was quite some time ago.
  12. Aug 25, 2019 at 7:14 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    I don’t think it’s the mod either because it’s not that I’m not getting an image it’s that the head unit is doing nothing. I unpluged the wires and at least then when it’s in reverse the screen goes blank to switch to “camera” mode.
  13. Aug 25, 2019 at 7:22 PM
    Shellshock
    Iowa
    This was the issue in my brothers truck. The easy way to tell is to see whether or not the reverse lights come on. If they don’t, it’s the sensor
  14. Aug 25, 2019 at 7:39 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Ohh I didn’t even think of that. I will have to check for those next time it happens. Guess I’ll be using that parking brake. Did he get it fixed easy?
  15. Aug 25, 2019 at 8:04 PM
    Shellshock
    Iowa
    His is a manual transmission, there’s a sensor in the side of the transmission that you just pop out and put in a new one. I assume the auto is something similar. It was like $30
  16. Aug 25, 2019 at 8:12 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Might just check the connector first.
  17. Aug 25, 2019 at 8:38 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    All connections are solid and firm. Seems to be like another user pointed out and the truck isn’t sensing I’m in reverse. I’m getting power to the camera but the radio doesn’t know to put on the camera.
  18. Aug 25, 2019 at 8:39 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yah, me. I meant check the connection on the sensor.
  19. Aug 25, 2019 at 8:39 PM
    cruxx
    Huy
    2017 TRD Sport
    Im thinking a loose connection for tge rear camera or else power. Then again it could be the switch. Just cuz it lights up does not mean it actually switches. I bought the old system where we had to split the connections. Had a problem with rear because i didnt crimp the split good enuf. Either way, you can always call the owner and he can help you troubleshoot. He was friendly when i called him on thanksgiving
  20. Aug 26, 2019 at 4:38 PM
    Snakedoctor
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Any idea where that sensor would be?
