Backup camera & reverse lights aren't coming on...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DueNorth, Oct 5, 2013.
  1. Oct 5, 2013 at 2:27 PM
    DueNorth
    DueNorth [OP] Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Hey guys got an issue with my truck that i'm hoping someone can help me out with... lately when shifting into reverse, my backup camera and reverse lights aren't coming on. It'll do this for a couple days and then all of a sudden it'll work a couple times.
    Has anyone else had this issue and/or whats the best way to go about fixing it? Thanks in advance!
  2. Feb 20, 2015 at 7:20 PM
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Bump, Ive been experiencing a similar problem lately. After driving, if I put the truck in reverse, the back up camera doesnt always come on. Not sure about the reverse lights. Doesnt sound like a common problem since this is an old thread with no replies.
    Any ideas??
  3. Feb 20, 2015 at 7:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the park neutral switch on the shift lever. It has to close in order to get power to the backup lights and the camera.
  4. Feb 20, 2015 at 7:36 PM
    gorillaford
    gorillaford Well-Known Member
    oregon
    2012 DCSB offroad MT
    had to replace the switch on my 2012 6spd mt at about 14,000 miles its on the right side. 2 wire switch
  5. Feb 20, 2015 at 7:37 PM
    ASUAviator
    Anchorage, AK
    Tacoma TRD Off Road
    Thanks! ill look under the center console and hopefully it will be pretty obvious
  6. Feb 20, 2015 at 7:41 PM
    gorillaford
    oregon
    on a manual you change it from under the truck. do not know about auto
  7. Feb 20, 2015 at 7:49 PM
    ASUAviator
    Anchorage, AK
    Tacoma TRD Off Road
    ive got an automatic. Id imagine its tied in pretty close the shifter
  8. Feb 20, 2015 at 10:07 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    Check your fuses
  9. Feb 20, 2015 at 10:14 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Shouldn't be any intermittency with a fuse.
  10. Feb 21, 2015 at 7:05 PM
    uscg2008
    coby
    If the fuse isn't completely broken and it could just be arcing sometimes. Just an idea, just check all reverse light related fuses with a light probe. Couldn't hurt to check
  11. Feb 22, 2015 at 7:15 AM
    DueNorth
    Perhaps check the last connection (plug) along the wiring harness from the camera going along the frame. That plug may have mud or water intrusion which could cause it to short and not work... Just an idea...
