Backup Camera to aftermarket screen HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xwillx93, Nov 24, 2011.
  1. Nov 24, 2011 at 10:08 AM
    xwillx93
    xwillx93 [OP] Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    I have a kenwood DDX616 (double din) for my radio. I've always known our trucks have the backup camera but i have NO CLUE how to hook it up? any links to someone whose done this would be helpful, but where can i find the other end of this backup camera cord???
  2. Nov 24, 2011 at 10:13 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    It runs from the camera in the tailgate to the screen in the rear view mirror you can find the cable between there, in my tundra I tapped into it at the mirror so I could leave the cord and all the plugs in tact for returning it to stock later.
  3. Nov 30, 2011 at 7:38 AM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    I'm in the middle of the same problem. Has anyone successfully paired the existing OEM backup camera from the lame mirror display to a Kenwood in a Tacoma? The Kenwood has an RCA jack on the back panel for a video input, but don't know where to pick up the video feed from tailgate. Also wondering if anyone knows what format the video feed is.
    Lastly, my 20-pin connector from the double-din Kenwood has a long purple/white wire labelled "Reverse"...to the reverse lamp switch/lamps I guess. Where did anyone find this connection?
    Lastly, lastly...I'm trying to tie in an Axxess ASWC steering wheel control module. I've seen posts where some tie the white/red wire to ground...I don't seem to have a white/red wire in any of the harnesses. It's not working correctly even though I can get some LED activity.
    I'm truly amazed at those that installed theirs in less than two hours. I spent six hours yesterday doing mine and still don't have all of it up and running. (I have the HU wired up and suspended from the mirror with a strap while trying to get the bugs out.)
    One problem I had was with the Crutchfield-supplied Kenwood 5180. They supply a 'cage' that looks like it should provide the mounting...not so Grasshopper. There's no way it could be used as such. Finally used the plastic mounting 'ears' and looks like it will work when I eventually get that far.
    Hell at the present rate I might install it with Velcro, looks like I'm going to be getting into it now and then if thing continue as they have been. I am impressed with the Nav though. It's picking up the birds, and correctly plotting the location, even inside the garage.
    TIA
    Whit
  4. Nov 30, 2011 at 9:37 AM
    platinumb
    Patrick
    denver
    yes you can tap the wire any place you want the easiest is actually at the mirrior. then its easy to put back to stock later just splice in an rca cable up there there is not an rca connection in the factory system so you have to solder it.
  5. Nov 30, 2011 at 10:02 AM
    wayne73
    wayne73 Well-Known Member
    Wayne
    St. Paul, MN
    2009 Tacoma Sport 4x4
    http://www.tacomaworld.com/forum/aud...elow-dash.html
    I cut back some of the insulation and soldered the wires rather than those shove in taps. Picture quality remained and is great on both screens.
  6. Nov 30, 2011 at 10:51 AM
    Whitster
    Whit
    Golden, CO
    OK thanks guys, great URL's, pics and finds.
    I did get the AXXESS adapter to work. Found the right color wires coming from a connector that was back hiding behind stuff. And the white/red DID need to be grounded.
    Whit
  7. Jul 10, 2017 at 3:18 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    sorry to bring up an old thread, but @ilubtimmyhos
    here we go man! :thumbsup:
    ilubtimmyhos likes this.
  8. Jan 22, 2018 at 1:42 PM
    Chiro22
    Chiro22 TacoTor
    Doc
    Bay Area
    2009 Tacoma manual
    Any idea which Double Din stereos are compatible with a 2009 Taco that has the regular stock mirror? Mine did not come with the back up mirror, it does have the camera though.
  9. Jan 22, 2018 at 1:46 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    I have the Boss NV something.... double din, navi, backup cam etc... works perfect in my truck... @ilubtimmyhos and myself are going to relocate my backup cam to it soon
  10. Jan 22, 2018 at 1:46 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Im ready bud.
    Chiro22 and Mr. Projekt[QUOTED] like this.
