Backup camera wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rich63, Jan 11, 2018.
  1. Jan 11, 2018 at 12:52 PM
    Rich63
    Rich63 [OP] Hobojo
    David
    Lexington, SC
    2016 Tacoma TRD Sport
    Hi. I bought a silver Toyota Tacoma Access Cab about a month ago and I want to become a member of your forum. I had bought a new 1979 Toyota 4x4 and loved it. Now and then I will have questions about the truck and I hope I can get help when I need it. I am attempting to install a back up camera and I need to wire into the reverse light in tail light. I need to know what color wire is for the power and what wire is the ground wire (I am assuming it is the green wire). There are five different color wires to chose from. I don't want to splice into the incorrect wire.
  2. Jan 11, 2018 at 1:13 PM
    Wheeler's Off-Road Inc
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
    Hey David,
    Welcome to Tacoma World and congrats on the new rig.
    Any auto parts store has a test light you can purchase for fairly cheap. You simply attach the test light ground clip to any solid ground (bare metal) and touch the tip of the test light to any wire end and it will light up and tell you which wire is hot. This goes for any wiring that you will need to conduct on cars and trucks safely. Just make sure you have a good ground for the test light or it will not work or light up for you. Also turn on the ignition to provide said wiring with actual power. Reverse would also have to be engaged to relay power to the reverse lights. Make sure if you have bare wire ends that are hot to keep them separated from the ones that are not or you will ground it out and pop a fuse.
    -Or find the right wiring diagram for your rig and find the color you need on the diagram.
    Rich63[OP] and tcBob like this.
  3. Jan 11, 2018 at 1:13 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Welcome!
    Rich63[OP] likes this.
  4. Jan 11, 2018 at 2:10 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    Rich63[QUOTED][OP] likes this.
  5. Jan 11, 2018 at 6:48 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    Tap into the one that goes to the reverse light bulb in the tail light.
