Backup Camera Wiring Issue
Discussion in 'Audio & Video' started by OB.BAJA, Sep 26, 2009.
  1. Sep 26, 2009 at 10:26 PM
    OB.BAJA
    OB.BAJA [OP] Well-Known Member
    Obed
    SoCal
    Planning to buy a backup camera for my taco but am not sure on where to run the wires through..that is do i have to drill a hole in the cab etc...thanks
  2. Sep 26, 2009 at 11:51 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    There's a rubber boot right under the driver's seat that makes it a breeze to install.
  3. Sep 28, 2009 at 10:20 PM
    digitalricepape
    digitalricepape Well-Known Member
    O.C.
    Running the wires through the boot you mentioned will lead to the rear end of the truck?
  4. Sep 28, 2009 at 10:56 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    it will drop it out below the drivers side door on the outside of the frame rail, then you can run it back along the rails
  5. Sep 28, 2009 at 10:57 PM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    The boot can lead to the rear of the truck. Just have to run the wires along the frame and bed.
  6. Sep 28, 2009 at 11:16 PM
    digitalricepape
    O.C.
    I see..and would I be running these wires alongside any other wires? (ie taillamps, etc.)
  7. Sep 29, 2009 at 7:26 AM
    dreamnz
    SoCal
    PreRunner
    Yes. I followed the existing wires wherever possible and just zip tied to it every 6-12 inches.
    The trickiest part is running/attaching between the fuel tank and frame, but it's not too bad.
  8. Sep 29, 2009 at 7:50 AM
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    There is a rubber boot under the passenger seat also. If you run the wires down the passenger side of the truck then you can avoid the gas tank.
  9. Sep 29, 2009 at 11:22 AM
    digitalricepape
    O.C.
    Got it. Thanks!
  10. Sep 29, 2009 at 2:51 PM
    dreamnz
    SoCal
    PreRunner
    That's funny! I feel like a bonehead. I should've checked for that before doing mine. :)
  11. Sep 29, 2009 at 9:41 PM
    lookylookitzadam
    Adam
    San Diego
    07 DC OffRoad
    It seems more convenient to run it on the drivers side because you can take the reverse light wire right at the drivers kick panel. Then again you can tap it at the light itself.
  12. Oct 1, 2009 at 9:35 PM
    WV_Tacoma
    WV_Tacoma Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    If I could do over again, I would run all the wires I could down the right side...No wires to speak of on the right side.......
