backup camera
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chiefdeck, Dec 7, 2015.
  1. Dec 7, 2015 at 6:31 AM
    chiefdeck
    chiefdeck [OP] Member
    when backing up at night picture from backup camera is snowy anybody else have that
  2. Dec 7, 2015 at 7:08 AM
    Doobiewah
    Doobiewah Well-Known Member
    Robert
    Flagstaff, Arizona
    RIP: 2016 Blazing Blue Pearl Tacoma Limited 4x4
    Mine is not very clear at night, either. At first I thought it might be the cold; however, it has recently been warmer and the issue is still there. Now, I'm wondering if it is the license plate lights causing the fade out....
  3. Dec 7, 2015 at 7:32 AM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    It's the reverse lights washing it out / causing the contrast. At least is what I found. I mean I don't need it to be that crystal clear for myself because I just use it for the red line and my garage door.
  4. Dec 7, 2015 at 7:36 AM
    chiefdeck
    I am not sure what you mean by reserve lifts
  5. Dec 7, 2015 at 7:37 AM
    ryanl2425
    ryanl2425 Doesn't work..Hit with hammer...Then hit harder
    Truckee, CA
    2015 MGM Tacoma DCSB Prerunner
    reverse lights
  6. Dec 7, 2015 at 8:03 AM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    There is a backup camera contrast adjustment easily available if you have the entune system. Check your owners manual.
    K13818 likes this.
  7. Dec 7, 2015 at 10:49 AM
    Wraith600
    Damn auto correct, yes, lights.
  8. Dec 7, 2015 at 10:50 AM
    Wraith600
    Yes but that is for the screen display not for the lens adjustment. I tried it already with the expected results. It does not change how the lens behaves only how the display is brought up when the camera is on and showing.
  9. Dec 7, 2015 at 11:30 AM
    Josh S
    Josh S Well-Known Member
    Josh
    Topanga, CA
    2016 Tacoma Limited 4X4 DC & 05 Tacoma 4X4 Double Cab
    05: Big Tires, Big Black Wheels, Leveled and raised a couple inches, Extra leaf in the back 16: Stock. For now.
    Lens flare from the reverse and/or license plate lights
  10. Dec 7, 2015 at 1:18 PM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    the backup camera is calibrated for the oem light bulbs and kelvin (2700).
    if you replace the oem bulbs with brighter and/or higher kelvin lights, you need to adjust the contrast/brightness setting in the main display.
