Backup Light not turning on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justaco, Jun 10, 2011.
  1. Jun 10, 2011 at 10:29 PM
    Justaco
    Justaco [OP] Member
    Justin
    St.Louis
    03 4WD Extra Cab SR5
    Ok so i was backing up a couple of nights ago and realized i couldn't see a thing so i checked to see if my backup light bulbls were burned and they werent and neither were any of the fueses.,. so because it is a manual trans does that mean there is a switch on the transmisstiion that "isn't switching" to turn the lights on?
  2. Jun 11, 2011 at 11:13 PM
    67tone67
    67tone67 Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    There shud be a switch yes..... Not sure if its on tranny or shifter on a taco..... Check all your wires..... Do all you other lights in rear work fine?
  3. Jun 13, 2011 at 9:05 PM
    Justaco
    Justaco [OP] Member
    Justin
    St.Louis
    yeah all the other lights in rear work fine
  4. Jun 14, 2011 at 8:22 AM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    I have had this same problem, however it has been intermittent. Usually slapping it out of reverse and back in has turned the light on. Must the a switch that the shifter closes or something. I have yet to diagnose mine.
  5. Jul 9, 2011 at 11:47 AM
    poppapump
    poppapump New Member
    mass
    03 SR5 extra cab 4x4
    Im having the same problem. Did you figure it out? Or any new ideas?
  6. Jul 9, 2011 at 4:38 PM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    manual trans???
    Heres a pic of where the sensor is...
    let me know if you need wiring diagram.
  7. Jul 9, 2011 at 4:47 PM
    spidy3
    Dom
    Upstate NY
    10 DC TRD Off Road
    If that doesn't work...
