Backwards on tow dolly?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cllowe24, Nov 24, 2020.
  1. Nov 24, 2020 at 2:21 PM
    cllowe24
    cllowe24 [OP] Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    So is there any reason I can’t just back my truck on the tow dolly and tow it with the front tires on the ground because I really don’t want to be taking the driveshaft in and out when I tow it.
  2. Nov 24, 2020 at 4:54 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    because the steering wheel? unless youve got a lock bar for it, i wouldnt bother. when i tow my auto ranger, i just unbolt the 4 bolts connecting the shaft to the rear diff and tie the shaft up on the frame.
    Kolter45 and Sterling_vH111 like this.
  3. Nov 24, 2020 at 6:32 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    But the steering wheel locks. That’s why I don’t understand.
  4. Nov 24, 2020 at 6:37 PM
    jorgem
    jorgem Well-Known Member
    I’m curious too, I was thinking of towing mine.
    I believe the steering lock is a tiny pin that will not be sufficient to go over pot holes, bumps and turns.
    Maybe device a steering wheel bar like an old club lock
    to clamp it to something.
  5. Nov 24, 2020 at 6:38 PM
    grrillA
    grrillA Well-Known Member
    Long Beach, CA
    '99 3.4L 4x4
    If it is not locked perfectly straight, you will ruin your tires...
    cllowe24[QUOTED][OP] likes this.
  6. Nov 24, 2020 at 6:39 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    I just hate the idea that I have to take loose my drive shaft when I tow it behind my camper.
  7. Nov 24, 2020 at 6:40 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    I can see that but even if my dolly is on a turn table?
  8. Nov 24, 2020 at 6:41 PM
    grrillA
    Long Beach, CA
    '99 3.4L 4x4
    Yea not sure, but I would imagine more people would take the easy route if it was safe and not going to damage anything though right?
  9. Nov 24, 2020 at 6:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    They make a thing for this.
    Personally, I wouldn’t want to run it on my truck.
    For simple reason- more parts = more to go wrong
    https://www.remcodsc.com/coupling/
    Others make similar products.
    That’s just the first one I found
    Jimmyh likes this.
  10. Nov 24, 2020 at 7:13 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    For towing a repo with rear lifted we'd wrap the seat belt around the bottom of the steering wheel, lock the belt, then cram the seat backwards. It's awkward without dead straight wheels as the towed vehicle will yaw a bit and crab sideways hanging out behind the truck. It works but I wouldn't suggest it.
    Alexely999 likes this.
  11. Nov 24, 2020 at 7:17 PM
    TnShooter
    Deogee
    STOCK
    Yeah, Definitely not recommended as you said.
    I see your (tow driver situation).
    Not your truck.
    You have a job to do.
    And the person being towed, probably shouldn’t have done what ever it was to get towed.
    Also, not picking on Tow Drivers.
    I know a few, and that is a tough job.
  12. Nov 24, 2020 at 7:52 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I guess I'm not totally understanding but if it was a manual just put it neutral and go with the front off the ground. Could you just put the auto tranny in neutral and go? Even if it means keeping the keys to the on (not start) position? I haven't been in a newer auto in awhile. All of my last vehicles have been 1995s
  13. Nov 24, 2020 at 7:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Problem is the prop shaft is spinning when the input is not, this isnt good for the tcase or the trans in a 2WD.
    Some trucks have sling drives on the prop shaft, but not the tacoma.
  14. Nov 24, 2020 at 8:12 PM
    DiscoYaker
    SE USA and Alaska
    Gotcha, when you say ..
    I'm guessing you also mean it wouldn't be good for a 4wd or 2wd. Just curious. Because the rear drive shaft will always be in play and t case and that is why someone would disconnect driveshaft? And if so you would disconnect shaft from the rear end (Near rear diff obviously in my head)
    A few bolts and a torque wrench (torque spec of course) to get it back in proper order?
  15. Nov 24, 2020 at 8:17 PM
    Bishop84
    Yup ideally you remove from the flange on the rear differential.
    On old floating axles, you'd unbolt and remove the axles from the hubs, but that's only heavy duty now.
    DiscoYaker[QUOTED] likes this.
