Bacon explosion!!!
Discussion in 'Food Talk' started by neontrail, Dec 26, 2008.
  1. Dec 26, 2008 at 8:51 AM
    neontrail
    neontrail [OP] ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Behold, BACON EXPLOSION!!! Here’s what you’ll need…
    2 pounds thick cut bacon
    2 pounds Italian sausage
    1 jar of your favorite barbeque sauce
    1 jar of your favorite barbeque rub
    To kick off the construction of this pork medley you’ll need to create a 5×5 bacon weave. If the strips you’re using aren’t as wide as the ones pictured, then you may need to use a few extra slices to fill out the pattern. Just make sure your weave is tight and that you end up with a nice square shape to work with.
    The next step is to add some barbeque seasoning on top of your bacon weave. Being the barbeque addict that I am, I whipped up a batch of Burnt Finger BBQ’s competition pork rub for this special occasion. Seeing as not everyone has the time, or the expertise, to create a tasty rub of their own, I would recommend trying Bad Byron’s Butt Rub, Rendezvous Famous Seasoning, or Steven Raichlen’s All-Purpose Rub.
    Now that you’re pork is well seasoned, it’s time to add more pork. Take two pounds of Italian sausage and layer it directly on top of your bacon weave. Be sure to press the sausage to the outer edges of the bacon creating a patty that is the same thickness all the way across. Most grocery stores carry loose sausage, so just pick out one you like. I chose to go with a mild sausage, but spicy would work just the same. If you really want to get crazy, take a stab at making your own homemade sausage.
    Next up is bacon layer number two. Take the remaining bacon slices and fry them up the same way you would for breakfast (or lunch, or dinner, or a midnight snack). If you like soft bacon, make it soft. If you like crunchy bacon, make it crunchy. If you like your bacon burnt to hell so the smoke detectors go off, then burn it to hell so the smoke detectors go off. These pieces are going to be a major part of the inner flavor of our sausage fatty, so cook them your favorite way. Personally, I like my bacon right at the point when it starts to get crispy, but hasn’t quite lost all of the softness yet. Regardless of how well done you like yours, you’ll need to crumble or chop the cooked strips into bite size pieces and place on top of the sausage layer. (Note-It’s okay, and encouraged, to snack on these pieces while your chopping/crumbling. But keep in mind that once those bacon morsels touch the raw sausage, you’ll need to resist all temptations to nibble. This can and will be difficult, but hospital trips are no fun, so stay strong.)
    Since this is a barbeque recipe, we need to add another layer of barbeque flavor. Take your favorite sauce and drizzle it all over the top of the bacon pieces. Personally, I prefer to use Burnt Finger BBQ’s homemade competition sauce, but if you’re torn on what brand to use I recommend Cowtown, Blues Hog, and Fiorella’s Jack Stack. Once you’ve sauced the bacon, sprinkle on some more of the barbeque seasoning you used on the bacon weave.
    Now comes the fun part. Very carefully separate the front edge of the sausage layer from the bacon weave and begin rolling backwards. You want to include all layers EXCEPT the bacon weave in your roll. Try and keep the sausage as tight as possible and be sure to release any air pockets that may have formed. Once the sausage is fully rolled up, pinch together the seams and ends to seal all of the bacon goodness inside.
    At this point we can start to see the final shape of our Bacon Explosion, but we’re missing one key item. To complte the constuction process, roll the sausage forward completely wrapping it in the bacon weave. Make sure it sits with the seam facing downward to help keep it all sealed up.
    Sprinkle some barbeque seasoning on the outside of the bacon weave, and now this bad boy is ready for the smoker. Cook your Bacon Explosion at 225 degrees in a constant cloud of hickory smoke until your Thermapen gives an internal temperature reading of 165 degrees. Normally this will take about 1 hour for each inch of thickness, but that could vary depending on how well you maintain your fire and also how many times you open the smoker to take a peek. Mine took about 2.5 hours, which was right on target with its 2.5 inch diameter.
    Now that our Bacon Explosion is fully cooked, we need to add some finishing flavors. Remember that barbecue sauce we used for inner flavor? We’ll be using that same sauce to glaze the cooked bacon weave. Using a basting brush, coat the entire surface with a thin layer of sauce. Sweet sauces are loaded with sugars, so they’ll give your fatty a nice glossy finish. Spicy and vinegar based sauces don’t contain as much, so they won’t set up as well. If you’re dead set on using those sauces, just cut them with a bit of honey and you’ll get the same effect.
    Slice the Bacon Explosion into quarter to half inch rounds to serve. If your roll was good and tight, you should now see a nice bacon pinwheel pattern throughout the sausage. Obviously pork is best served by itself, but if you feel the need to make this meat monster into a sandwich, try placing a couple Bacon Explosion slices on a warm Pillsbury’s Grands Biscuit. You’ll reach pork Nirvana is no time flat!
    source
  2. Dec 26, 2008 at 8:54 AM
    coppert
    coppert Mall Krawler
    Travis
    916
    I can feel my arteries clogging just looking at that thing! But damn my mouth is watering now. :drool::drool::drool:
  3. Dec 26, 2008 at 8:55 AM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
  4. Dec 26, 2008 at 8:56 AM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    Holy crap!!!! That's awesome!!! I LOVE bacon and I LOVE Italian sausage. May try this one
  5. Dec 26, 2008 at 8:58 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  6. Dec 26, 2008 at 9:11 AM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    all i can say is WOW:eek: i want
  7. Dec 26, 2008 at 9:14 AM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    God Neon are you like a part time chef or something. i mean you always come up with these GREAT new recipes and stuff. i did the christmas cookie recipe. it was delicious
  8. Dec 26, 2008 at 9:41 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    that looks fkn tasty.... awesome!
  9. Dec 26, 2008 at 9:48 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    X2, must of gained 5 pounds already.
    Keep the drinks coming on that bacon deal.
  10. Dec 26, 2008 at 9:51 AM
    neontrail
    Idaho
    yup..lol
    thx man
  11. Dec 26, 2008 at 5:05 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Great writeup on a tasty twist on bacon, when my son sees this he may want you to adopt him:Dlol.....he is nuts over bacon!:D Thanks for sharing!!
  12. Dec 26, 2008 at 5:10 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    I bid you a long life.....
    LMAO
    Sounds delicious man!
  13. Dec 27, 2008 at 2:39 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    That looks fantastic! :hungry:
  14. Jan 9, 2009 at 8:48 AM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    holy shit i want that
  15. Jan 9, 2009 at 9:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    I want to stick some taters n' onions in that mess. Damn that looks tasty.
  16. Jan 9, 2009 at 5:51 PM
    hoosiertaco
    Hey Neon, my nine year old son I mentioned above, has been driving his mother crazy for this every since I printed it out and laid it on the counter. She'll get to it eventually I hope, or he'll continue to drive her crazy!:D Short trip for her I'd say;)hehe
  17. Jan 9, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When I saw the title of this thread, I thought it was like My Bacon Chernobyl. Nothing like it though.
  18. Jan 9, 2009 at 6:00 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i put bacon on cake...
    hmm you know what would be good on this burger?? a ham sandwich!!! we could used doughnuts as buns.... watchout mcgriddle here comes the doughnut ham hamburger!!!!
  19. Jan 9, 2009 at 6:00 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    jim gaffigan
  20. Jan 9, 2009 at 6:37 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Neon, you are my hero. When I didn't think pork sausage or bacon could really be improved upon, you combined the two. You've created something so fantastic that no words exist to describe it. I am forced to make one up.
