bad 02 sensor
Discussion in 'Technical Chat' started by TacomanTRD, Sep 25, 2010.
  1. Sep 25, 2010 at 6:00 PM
    TacomanTRD
    TacomanTRD [OP] New Member
    02BLK4DRTRD
    Researching 3" Suspension Lift
    i have a 2002 3.4L V6 4dr TRD. check engine light is on, ran code, say 02 sensor. any body know how to deterime which one? when i get out of the truck is smells like it is running rich. also anyone know the cheapest place to buy the 02 senser?
  2. Sep 25, 2010 at 6:40 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    What code was it?
  3. Sep 27, 2010 at 4:13 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    x2 that that code should tell ya which is bad...but strongly suggest doing yourself a big favor and replace them all. If one's bad the others aren't far behind, or probably are bad just not enough to trip a code yet.
  4. Sep 27, 2010 at 6:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Most likely the front one.... as they're closer to the hot gasses of the engine.
    Did you get the codes pulled from the dealer? They should be able to tell you which sensor it was....
    http://www.lieblweb.com/o2replacement.html
