Bad 2015 Tacoma transfer case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by csampley88, Feb 17, 2021.
  1. Feb 17, 2021 at 11:52 AM
    csampley88
    csampley88 [OP] New Member
    Limited 2015 Tacoma double cab 4WD
    New to thread. Have a 2015 Tacoma 4WD w 65k miles. Bought used from dealership w 15k and i have it serviced at same Toyota dealership for oil change, tire rotation and etc.
    we got some snow so was using 4WD and started hearing rough noise(like grinding type). I have used the 4WD since purchasing truck maybe 4x and has 70-80 miles of use. Took to dealership and said there were 2 leaks and the oil was almost empty from transfer case. I asked if seals could be replaced from where it was leaking and said that it’s leaking from side and another spot where seals can’t be replaced and said new transfer case w labor would be $5100.
    And my power train warranty is 2 mo outside the 5yr and 5k miles outside the 60k. Is there even a prayer that Toyota would cover it since it’s always been serviced by Toyota and has such little use?
    am I totally getting reamed and could get this done much cheaper elsewhere
    I don’t know much about vehicles so any advice would be appreciated.
    Thanks
  2. Feb 17, 2021 at 11:59 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Welcome to TW! Look into the FJ transfer case swap. You get a much better transfer case for much less than $5100
  3. Feb 17, 2021 at 12:05 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  4. Feb 17, 2021 at 12:10 PM
    2012Taco
    2012Taco Well-Known Member
    NJ
    '12 DCLB TRD
    OME 886's & Dakar's & LR UCA's, LT265/75 Duratrac's on Countersteer Offroads, 100RCC, ARB 50 fridge/freezer, ARB bullbar w/ Warn 9.5xps, dual battery setup, on board air and water, PrInSu topper rack carrying the gear and more to come!
    Check your service records, the dealer should have been checking t-case fluid level (I forget at what mileage intervals but it's in the manual). At 65k it should have been changed by now too (probably twice IIRC). I'd push the issue with them if they've been pencil whipping the service sheets.
  5. Feb 17, 2021 at 12:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Ouch.
    There are instructions in the owners manual to how owners need to regularly engage 4wd to keep it fully functional and lubricated.
    Once you get your situation resolved, it will be a good idea to do so.
    I also would be shopping for other opinions on both servicing what you have and/or replacement of what you have.
  6. Feb 17, 2021 at 3:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d consult with a Transmission Shop.
    Those guys deal with Transfer cases all the time.
    You might find one that is willing to do a swap for you.
  7. Feb 17, 2021 at 6:19 PM
    AKguide
    AKguide Active Member
    Alaska
    15 AC TRD Off Road 4x4
    Not too hijack this thread, but my 2015 makes a considerable clunk when it is switched into or out of 4 wheel drive. Is this normal with these trucks? It doesn't do I every time, but more often than not and has done it since new.
  8. Feb 17, 2021 at 6:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    And yet........ you couldnt start your own thread? :confused:
    LoveableWerewolf likes this.
  9. Feb 17, 2021 at 6:25 PM
    TnShooter
    Deogee
    STOCK
    Yeah, that sounds normal.
    If the drivetrain has any strain on it while while engaging/disengagement it will be “louder”.
    You can sometimes make it quieter by going to neutral. Let the truck come to a rest on its own, and then flipping the switch. But this isn’t always doable on hills and such.
    But yes, it’s normal.
  10. Feb 17, 2021 at 6:28 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Yeah, they are reaming you.
    Junk yard cases are only like $200-400 and would be completely OK to install, they rarely go bad. An experienced shop should be able to install one in less than a day.
    noco_taco and TnShooter like this.
  11. Feb 17, 2021 at 7:07 PM
    AKguide
    Alaska
    Well it is related to the original topic and doesn't seem fitting to start a whole new thread for a simple question, but thank you for your contribution, you seem swell.
    CadCamMan likes this.
  12. Feb 18, 2021 at 7:09 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    I've got a transfer case in Colorado I'll sell ya for cheap if you're close enough to come get it
    TnShooter likes this.
  13. Feb 18, 2021 at 7:26 AM
    rns0504
    rns0504 Well-Known Member
    DeBary FL
    2015 Tacoma TRD Off Road
    'Stock-But-Capable' - I have four other 4x4s to mod
    I bought a transfer case for my 2015 for $200 shipped on ebay.
    Changed it in my driveway in about 2 hours. Super simple, didn't have to drop transmission or anything stupid like that.
