Bad Alternator, Really?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kgarrett11, Feb 24, 2019.
  1. Feb 25, 2019 at 5:22 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    I had a similar situation with wife's CRV. Battery dead after 5 years so replaced it. With new battery in, no charging with engine running; 13.8V. Found out that Honda's do not charge the battery unless either the charge on the battery is below a certain level, or the vehicle is decelerating (supposedly for better fuel economy). Don't think Toyota does this like Honda.
  2. Feb 25, 2019 at 8:51 AM
    kgarrett11
    kgarrett11 [OP] Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Good Morning all. Thanks for your input. The truck did start today after sitting 22 hours. I tested it again this morning:
    Yesterday's Results
    Off- 12.33
    On-13.94
    On with load- 13.85
    Off again- 12.51
    Today's results
    Off- 12.14
    On-14.12
    On with load- 14.05
    Off again- 12.45
  3. Feb 25, 2019 at 8:55 AM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    It was ur corroded terminals
    whatstcp likes this.
  4. Feb 25, 2019 at 8:59 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like the alternator is charging fine, time will tell on the battery.. to me, 12.1 volts is a little low
    But, it is starting the truck, so we'll see if it continues to cooperate. Over time, you'll be able to see if the battery is up to the task
  5. Feb 25, 2019 at 9:16 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Thank god. So glad this is a free fix. Will continue to monitor and report back if things change
  6. Feb 25, 2019 at 11:35 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    These trucks ain't some 1966 vw bettle or similar. Lol
  7. Feb 25, 2019 at 11:36 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    OP I would replace that battery under its warranty.
    kgarrett11[OP] and christian06 like this.
  8. Feb 25, 2019 at 3:03 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    How you know i had a '66 Bug? You stalking? :D
    You'd be surprised how many "old timers" do this.
  9. Feb 25, 2019 at 3:14 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Do you really? Lol.
    My first was a 64, then a 70 followed by a 63.
    It is a great trick for testing the electrical on a them.
  10. Feb 25, 2019 at 3:31 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    start truck. disconnect negative of battery. if truck shuts off, bad alternator, keeps running, good alternator.
  11. Feb 25, 2019 at 4:26 PM
    Yota_Ivan
    Arlington, TX
    Yup. Had a 66 ragtop, a '75 fuel injection that got chopped up into a baja bug and a '65. My uncle currently owns a 71 beetle and a 70's Type 2 pickup (Transporter) with the extended cab.
    Fun little cars to have growing up in the Caribbean. Small cars for small island.
    TrdSurgie[QUOTED] likes this.
  12. Feb 25, 2019 at 5:24 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    A battery can still start with only 10.5v, but it will really struggle. Amps are another topic.
    Read over this:
    https://www.customtacos.com/tech.ol...f/06toyrm/06toypdf/06rmsrc/rm2006ta/02400.pdf
    Your alternator needs to put out a higher voltage than the battery maintains (12.8) and they usually degrade over time. Don't worry if you see lower volts in warmer weather. Grab one of these cheap volt meters and keep an eye on it from the drivers seat.
    https://www.amazon.com/Digital-Volt...CCS2RMPMTET&psc=1&refRID=88QMA6Q9XCCS2RMPMTET
    kgarrett11[OP] likes this.
  13. Feb 25, 2019 at 8:01 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    ehh no I don't think so chief.
    b_r_o likes this.
  14. Feb 25, 2019 at 8:08 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    how so? the engine will run off the alternator if its still good. the battery is just there to crank over the starter
  15. Feb 25, 2019 at 8:34 PM
    #35
    6 gearT444E
    Deep South
    Herculiner Hootus
    The ECM will have no ground reference, try it and report back let us know how it goes.
  16. Feb 26, 2019 at 3:53 AM
    #36
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The alternator is grounded internally . It should work.
    The electronics might not like the resultant spike but it should run without the battery connected.
  17. Feb 26, 2019 at 4:40 AM
    #37
    6 gearT444E
    Deep South
    Herculiner Hootus
    I do not disagree with your statement, however the electronics do not work well on a floating ground. Should work and does work are two different outcomes. Try it and report back
  18. Feb 26, 2019 at 9:41 AM
    #38
    Larzzzz
    Larry
    MA
    It's not floating because the alternator negative terminal is grounded to the vehicle through the alternator body. The battery does serve to stabilize the alternator voltage somewhat... Somewhat because as we see the voltage rises when the engine is running.
  19. Feb 26, 2019 at 2:44 PM
    #39
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    if I ever have an issue with my battery and or alternator I will try it and let you know hahaha I do see what your saying tho
  20. Feb 26, 2019 at 2:59 PM
    #40
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This, it was less risky in cars made in the 1980s versus now. Not worth the risk.
