bad axle seal or synthetic oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Dec 25, 2009.
  1. Dec 25, 2009 at 8:11 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    ok, so about a year ago I had a rear axle seal go bad, i got my mechanic to replace it, then a couple months ago I did a rear diff fluid change, now, i recently saw some fluid coming from the rear axle seal again, it sprayed up all over the inside of my fender well. so I'm wondering if it's the synthetic fluid.. or the axle seal again? It's gotten low so my plan is to fill it with regular diff oil and ditch the synthetic for now. whatchya think?
  2. Dec 25, 2009 at 8:29 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    as long as you drain all the synthetic then you should be fine, dont mix synthetic and regular oils though..
  3. Dec 25, 2009 at 8:30 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    gotchya! damn I wish I was home, with tools..
  4. Dec 25, 2009 at 8:33 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Sounds like the seal again. Synthetic oil causing a seal to go bad is now known to be a myth, or so I have been told by many.
    Sounds like he installed it wrong or a bad seal?
    I think staying with synthetic is better, but you can go with dino, it will be OK.
  5. Dec 25, 2009 at 8:35 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    alright, I'll refill with synthetic until I can get home and fix it. sucks to pay for it twice in a year
  6. Dec 25, 2009 at 8:37 PM
    98_Mud_bug
    lucedale Ms.
    after i got it fixed i would go back to synthetic, im runnin royal purple gear oil in my diff's
  7. Dec 25, 2009 at 8:42 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yeah man that sucks! I recently noticed some oil residue on the bottom of my diff. So I torqued all the nuts to factory specs, and all of them were lose, by a lot.
    After cleaning off the bottom and putting synthetic oil in, I haven't noticed any more oil residue.
  8. Dec 25, 2009 at 8:43 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I can assure you it is the seals, and not the oil. Contrary to popular belief, synthetic oils do not cause oil leaks, rather bad seals cause oil leaks. Toyota doesn't make the best axle seals so it wouldn't surprise me one bit that the seal is leaking, but if your mechanic did not install the seals properly they will also leak and fail prematurely.
    You can mix synthetic and dino oils all day without and ill effects too.
  9. Dec 25, 2009 at 8:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    weird, but I'll figure it out. I'm glad it's not cause of the synthetic. new seal and a breather extension when the holidays are over
  10. Dec 25, 2009 at 8:45 PM
    SC4333
    Grant
    San Antonio, TX
    Your breather isn't clogged, is it? Thats another thing that will cause the seals to fail.
  11. Dec 25, 2009 at 8:45 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    it shouldn't be, but I'll have a look tomorrow before my trip.
  12. Dec 25, 2009 at 8:46 PM
    98_Mud_bug
    lucedale Ms.
    ive always heard that mixing weights was ok but not synthetics and regular oils. but i may be wrong..
  13. Dec 25, 2009 at 8:49 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    better safe than sorry, I'll stick with what's in there, and replace when I get a new seal.
  14. Dec 25, 2009 at 8:57 PM
    SC4333
    Grant
    San Antonio, TX
    Nope, it wont hurt a thing. Now I wouldn't go out of your way to do it because its pointless, but a mix wont hurt anything. After all, most all 'synthetics' are actually blends of dino and synthetic base stock.
  15. Dec 25, 2009 at 8:58 PM
    98_Mud_bug
    lucedale Ms.
    wow i learned sometin new today ha ha
  16. Dec 25, 2009 at 8:59 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    maybe, sc4333, not to be rude, but how do you know it won't hurt? any explanation of why or why not?
  17. Dec 25, 2009 at 9:17 PM
    SC4333
    Grant
    San Antonio, TX
    To put everything into the simplest terms oil is categorized and rated by different standards. Mixing oils, regardless of synthetic or dino, in the same standards will have no ill effects. Mixing oils with different ratings is still possible and can almost always be done without encountering any problems. The place an issue could potentially arise when mixing outside of a compatible rating is with additive packs and don't jive well with each other.
    For instance, what goes into my taco is Mobil1 5w-20. It is a ILSAC GF-4 API SM, SL/CF oil. Technically I can take it and mix it with any SM, SL or CF oil with complete compatibility, synthetic or not.
    If you want to learn more about oils, check out bobistheoilguy.com. It is a really informative site, with all kinds information on oil. Most likely more than you would ever want to know.
  18. Dec 25, 2009 at 9:19 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    great! thanks for the info!
  19. Dec 25, 2009 at 9:36 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    also check the rear diff breather. If its stuck shut the pressure build up in the rear diff will push out the seals...
  20. Dec 25, 2009 at 9:37 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yea thats what they said on ttora too, thanks for your help. I'll check in the morning
