Bad ball joint faliure
Discussion in '1st Gen. Tacomas (1995-2004)' started by m22m46, May 28, 2012.
  1. May 28, 2012 at 6:56 AM
    m22m46
    m22m46 [OP] Member
    steven
    guichon,Uruguay
    02 tacoma
    my 02 taco just gave up i was driving on a road around 45 hit a small bump and bam wheel falls an i grind to a halt 50 feet from the bump now problem is i live in south america. What are the best parts and are japan parts cheap its a 2002 tacoma 3rz 2.7 manual 5 speed
  2. May 28, 2012 at 7:02 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Parts are rarely cheap.
  3. May 28, 2012 at 7:30 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Instagram- venturajuan23
    Either buy stock replacement or moog Don't buy any Chinese off brand shit
  4. May 28, 2012 at 7:44 AM
    m22m46
    m22m46 [OP] Member
    steven
    guichon,Uruguay
    02 tacoma
    are there any good diagrams for the front axle and cv joint to the front diff?
  5. May 28, 2012 at 10:24 AM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
  6. May 28, 2012 at 12:20 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    holy shit:eek: that is horrible. Any indication of ball joint failure before this? Were they leaking bad? Torn boot? Grease everywhere?
  7. May 28, 2012 at 10:56 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Before you get too worked up about this, There is some prevention stuff you can do for yourself.
    When a wheel comes off like this, it's usually a failure of the mount on the LCA, not the ball joint itself. The BJ assembly is held on by 4 bolts. If you look closely at the pic the OP provided, you will see the LCA and 2 of the 4 holes for the BJ assembly mount.
    If you loose 2 bolts it is enough to cause the other 2 to shear under the stresses. Mark (The Raisin) had this happen to his a few months ago. Lisa (MTgirl) also had this happen. On hers tho the wheel did not come off completely. She caught it just in time and was able to tow it to a shop for repairs.
    You can crawl under your truck and check the 4 bolts that hold the BJ and spindle to the lower control arm. I can't recall exactly what the torque spec is but just make sure they are tight.
    I actually replaced all 8 bolts on mine before we went to moab.
  8. May 28, 2012 at 11:01 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    OP, call Toyota and give them your VIN to see if your truck was included in the LBJ recall, and if it was ever performed. If not, they should strongly consider fixing it for free for you. And apologize for almost killing you.
  9. May 30, 2012 at 2:52 PM
    m22m46
    m22m46 [OP] Member
    steven
    guichon,Uruguay
    02 tacoma
    there is no way i can bring it back to the states i live near brazil... i checked under the truck both arms were fine when i left no grease any where, in the pic the grease came out of the front tripod those 3 ballbering on the end of shaft. when i took of the lower ball joint on the wheel hub the screws were so tight like if they were from factory it has 150k miles now broken. the bolts are still yellow marked
  10. Jun 1, 2012 at 1:13 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    If you replace it I would look into moog ball joints. A bit pricey but solid.
  11. Jun 1, 2012 at 9:17 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Just did this! Install was about an hour to do both sides, and you already have a head start on disassembly...:cool: Not funny but anyway Goodluck with the matter, and glad you and or passengers are all safe!
  12. Jun 1, 2012 at 9:34 AM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    Get MOOG. Check online for prices. I have found them on Amazon cheap.
  13. Jun 4, 2012 at 2:22 PM
    m22m46
    m22m46 [OP] Member
    steven
    guichon,Uruguay
    02 tacoma
    yea i ordered moog parts but i got triple 555 japan lower ball joint , the upper ball joint is moog i just need to order the steering rack points
  14. Aug 7, 2012 at 7:56 AM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    05/ 07,09/11Tacoma access cab 4x4
    First gen Tacomas has bad ball joint design..its a pull apart design and if ball comes put of socket it fails catastrophicaly!! Second gen is a push together design a d wont fail and allow the wheel to fall off!!!
  15. Aug 27, 2012 at 3:00 PM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    I feel for you as i recently had this happen as well.. Lower Ball joint seperated at the socket.. Mine were aftermarket brand (mevotech, and would never buy again). As in your case this could have been deadly on the freeway. I'm buying my parts from rockauto.com Moog is good and raybestos professional are good too i hear. (i'm going moog).. New CV Axle is best bought with lifetime warranty through a local parts distributor and i was able to get mine for $70USD..
  16. Aug 27, 2012 at 3:01 PM
    marcchrisv
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    tear down pic
  17. Aug 27, 2012 at 3:05 PM
    marcchrisv
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    ps.. those ball joints were replaced about 20K miles ago.. never going cheep again..
  18. Aug 27, 2012 at 10:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The socket and the ball look dry as a bone. Were they cleaned before you took the pic?
  19. Aug 28, 2012 at 12:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I thought the same thing. Looks like it was dry for a while too, looking at the wear pattern on the ball. This was not a sudden failure. You should never see this with 20K on a ball joint.
  20. Aug 29, 2012 at 7:49 AM
    Milowilli
    Milowilli Milowilli
    Miles
    Naples FL
    Toyotas stupid non Failsafe design!!! Balljoint under tension all the time and fails catastrophicaly. Thank god they realized the problem and changed it to a compression balljoint on the newer trucks. First gen Tacoma balljoint design was a carry over from the Torsion bar trucks..difference is the top balljoint t was the load carrier and of the compression design..the lower was an idler minimal load design. First gen Tacoma has the lower balljoint as the load carrier with pull apart tension design..foolish idea!!! Hence the catastrophic failures.
