Bad battery or alternator? Or something else?
Discussion in 'Motorcycles' started by Styx586, Feb 18, 2013.
  1. Feb 18, 2013 at 8:10 PM
    Styx586
    Styx586 [OP] Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Ok so I went out to my bike (02 Ninja ZX-9r) yesterday, turned the key and got nothing. No lights no power to anything. I jump it with my truck and it fires right up, i let it run for ~10 minutes then pull off the cables, but won't run after I removed the cables... Shouldn't it continue to run? Is my battery totally fried or is the alternator not charging the batt properly? Thoughts?
  2. Feb 19, 2013 at 10:50 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
  3. Feb 19, 2013 at 10:52 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    start with a new battery. odyssey makes good ones for bikes. i dont think it would run without the battery... i used to hook my 4 wheeler up to a battery tenderer when i wasnt using it. they are cheap at wal mart, and it always fired right up when i went to take it out. battery was shit but the tenderer worked fine.
    is your bike EFI?
  4. Feb 19, 2013 at 10:58 AM
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    Sounds like a battery problem. How long was it since you ran it last? You need to charge the batteries once in a while when storing your bike. You can check the alternator with a volt meter across the battery. It should climb from 12 to 14 volts when started, if it doesn't check/replace the alternator/regulator. (most bikes don't run without a battery needed to power the alternator field.)
  5. Feb 19, 2013 at 11:08 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I'm 98% confident it is your battery.
  6. Feb 19, 2013 at 11:18 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    what's your battery voltage while running? i had a similar situation with my old 06 GSXR 600. faulty regulator/rectifier and burned two coils on my stator so my charging system wasn't functioning.
    you could charge the battery up and it would run off the battery until the voltage dropped too low.
    get it taken care of asap or it will take out your battery too.
  7. Feb 19, 2013 at 2:57 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Bike isn't EFI it's carbureted. Last time i ran it was like less than a week ago. I checked the voltage with the bike off its like 2 volts. I havent tested it while running though i think i'll do that next. Cant do anything today it's raining and i dont feel like getting shocked today. lol thanks for the input guys...
  8. Feb 19, 2013 at 3:01 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Stator problem or regulator/ rectifier. Check all connectors of these too. I had a loose wire inside the case of my LTZ, where it hooked to the stator, that caused this same problem.
  9. Feb 19, 2013 at 3:03 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Yea im thinking this may be the case. I had to replace my stator cover like a month ago so maybe i f***ed something up? I swear this bike is nothing but problems. lol
