Bad Bearings on Front Axles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dan T, Oct 1, 2023.
  1. Oct 1, 2023 at 9:54 AM
    Dan T
    Dan T [OP] Well-Known Member
    Dan
    CT
    Tacoma 4 cyl
    I'm wondering if I have bad bearings on my 2017 front axles. I'm hearing a clunking sound from the front, and I found a little play on the driver's side front axle where it enters the differential. Bad bearings?
    If they need to be replaced, is it best to go OEM bearings again or a bushing that I saw on YouTube that is being used?
  2. Oct 1, 2023 at 10:19 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    sarcastictechsupport likes this.
  3. Oct 1, 2023 at 10:47 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There’s always a little bit of play at the diffs if you move the CV shaft around, at least in my experience there is, and that’s with both the stock needle bearing and the ECGS bushing.
    As for the front clunk, mine does that on every hard bump. Pretty sure it’s due to the low torque value for the front strut bolts. I changed to a full width bolt that fits the strut sleeve a bit better and it helped not make the noise as often, but it’s still there. I’m not sure why the strut torque specs are so low, my previous mid size trucks were around 150-175 ft lbs, not 61ft lbs.
  4. Oct 5, 2023 at 6:15 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
  5. Oct 5, 2023 at 6:16 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    I'll look to see if I'm have the same issue as you. Thanks
  6. Oct 5, 2023 at 6:35 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Simplest first: check your wheel lug nuts for proper torque. It'll clunk if they loosen up.
    3JOH22A likes this.
  7. Oct 5, 2023 at 12:07 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i wish everything was that simple
  8. Oct 6, 2023 at 11:51 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    The bolt you replaced and the 61 FT LBs torque that you mentioned was that for the lower bolt of the shock absorber/coil spring to the control arm?
    A made a list of the torque spec's for the front suspension so I can double check these items.
  9. Oct 6, 2023 at 11:57 AM
    BLtheP
    Plano, TX
    Yes. 61 seems much too low when other midsize trucks are slightly less than 3x that torque.
  10. Oct 6, 2023 at 12:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Clunking sound from the front is usually something else, like a pulverized lower shock bushing, loose lower shock bolt, loose UCA bolt, pulverized radiator support bushing (if stock), loose radiator support bushing bolt (if upgraded)...
  11. Oct 6, 2023 at 12:23 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    When is it clunking?
    Bumps? Turning? Reverse?
    All the above posts are good suggestions.
    I haven't seen swaybar links mentioned. loose links and sway bar can clunk.
  12. Oct 6, 2023 at 12:40 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Check your ball joints! Jack up the front of the truck and see if you can "wiggle" the tire top and bottom.
    If your truck is unmodified, I would suspect the ball joints over bearings.
  13. Oct 9, 2023 at 5:37 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    Guys, you all have given me good suggestions and somethings to look at. With over 60K miles I would be surprised to find something worn out. Thanks
    I'll post an update when I find where the noise is coming from.
  14. Oct 9, 2023 at 7:42 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For real?
  15. Nov 14, 2023 at 5:00 AM
    Dan T
    Dan
    CT
    Tacoma 4 cyl
    LOL.
    ty-po. I should have read what I typed before posting. That should have read...wouldn't... Thanks for pointing it out.
    Anyway, I got each wheel off the ground and with the wife's help checked the front suspension for lose and worn parts and everything looks good. The noise has to be in the body somewhere up front. It was still good to look over the front suspension parts.
