Bad blower motor or something else?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rlf, Jan 20, 2012.
  1. Jan 20, 2012 at 12:25 PM
    rlf
    rlf [OP] New Member
    TX
    07 PreRunner SR5
    None
    Well, I have no air blowing in my 07 Taco. I have read threads about the blower working only on high and not on the lower settings. Mine is not blowing at all. I took the blower off and checked the voltage coming to it. When I turn the blower onto the lowest setting, the voltage jumps from 0.0 to 12.34. When I turn it up to the higher settings, it stays on 12.34. I checked the continuity of the motor and my volt meter tells me that there is a circuit. Not knowing that much about it, could it be a bad motor or something else?
    Thanks in advance.
    Randy
  2. Jan 20, 2012 at 12:50 PM
    Large
    Large Red
    Motor may have crapped out. If you turn the knob & there is 12v DC going but the motor isn't running.
