Bad body panel alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Dec 15, 2022.
  1. Dec 18, 2022 at 8:07 PM
    #61
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I wouldn't recommend that. They aren't going to treat you better if they complain about this. They'll treat you worse for complaining about it. You'll be that problem customer. The annoying person complaining about things they can't do anything about.
    This is pretty minor. If the gaps were bad in other areas, and it was before you drove it off the lot, then maybe you'd have something here. But given the specific situation, you're gonna just have to deal with it.
  2. Dec 22, 2022 at 5:45 PM
    #62
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just checked my 07 today. The gap on the passenger side is exactly the same as the OP's... drivers side is even. Do i care enough to do anything about it? No.
  3. Dec 22, 2022 at 6:07 PM
    #63
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    My '08 gaps are straight as a poker.....trade ya!
