Bad BRAKE ISSUE
Discussion in 'X-Runners' started by insp58255, Oct 20, 2024.
  1. Oct 20, 2024 at 5:36 PM
    insp58255
    insp58255 [OP] Member
    2002 Tacoma SR5 4x4
    I have an 01 SR5 4x4. My brakes pull hard to the left when applied. The jerk free. I changed bad brake hoses. Now what's next? Calipers then I'm lost after that.
  2. Oct 20, 2024 at 5:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Your right caliper pistons might not be working/rusted
  3. Oct 21, 2024 at 5:45 AM
    insp58255
    2002 Tacoma SR5 4x4
    That's first thing I thought. If it's not hoses or Calipers what would next thing be Master Cylinder?
    TY
  4. Oct 22, 2024 at 10:55 PM
    DoktorSlowburn
    DoktorSlowburn Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    Take this advice with caution, as you will risk getting air in the brake lines. But here’s what I would do.
    Disconnect the brake line hose from the caliper. push the brake pedal all the way down and see if anything comes out. Don’t let back up on the pedal until you reconnect the hose.
    If nothing comes out then you’ve got a clog upstream. If it does, it’s the caliper.
    I had a clog in my drivers side caliper a couple weeks ago and that’s how I diagnosed it. I ran some brake cleaner through the caliper, let it dry and reinstalled then bled it.
  5. Oct 22, 2024 at 11:07 PM
    insp58255
    2002 Tacoma SR5 4x4
    I just replaced both calipers. Has pull to left but this may be due to an alignment issue because I also had new rack installed. Apparently the steering wheel wasn't e to explain it. So now the issue is that pulls to lesft when braking then steering wheel centers then jumps to right. Weird I don't know how el
  6. Oct 22, 2024 at 11:10 PM
    DoktorSlowburn
    Escondido, CA
    Sorry, didn’t see that you had replaced the calipers.
    What you’re describing definitely sounds alignment related, especially if you didn’t get one after changing the rack. Sounds like there’s a significant amount of toe out on the drivers side. Or toe in on the passenger.
