Bad clutch or bad synchros?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmm275, Dec 14, 2011.
  1. Dec 14, 2011 at 9:30 AM
    cmm275
    cmm275 [OP] Well-Known Member
    Northern California
    2019 TRD Off-Road
    My truck: 2002 Tacoma 4X4 SR5 TRD 5speed
    I just purchased this truck with 153,000 miles on it. It is in really good shape, but there is just one thing that is bugging me...
    Simple explanation: hard to get it into gear.
    Detailed explanation: All gears are hard to get into unless the clutch is fully depressed. However, fourth gear is the worst. I will go to put it in gear and the stick will wait til the revs almost match up to pop in. Like there is a wall blocking it. The other gears do it a little bit but not as bad.
    I have no records of maintenance from previous owners.
    My troubleshooting so far:
    -having to fully depress clutch makes me think its clutch or clutch hydraulics
    -all gears having the problem to a different degree makes me think its synchros
    -truck does not roll forward with clutch depressed in first gear
    -gears do not grind going in
    -pushing on each gear without clutch in makes revs drop about 100
    -double clutching does not seem to help
    So... what does everyone else think it could be????
    Bad clutch? or bad synchros?
    Should I start by bleeding clutch master?
    Or replacing the tranny oil? (have not checked it yet)
    Please help. Thank you.
  2. Dec 14, 2011 at 9:36 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    my friends ranger is in the shop for the same problem... they said it's the clutch master
    cruxofthebisquit likes this.
  3. Dec 14, 2011 at 9:41 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Subbed to hear some replies. Mine is starting to do something similar... Difficult to get in 1st unless stopped completely, and when doing the 1-2 shift theres always a clunk unless its a slow shift where the RPMs are about matching the gear. 131xxx miles
  4. Dec 14, 2011 at 10:05 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    I have that same 1st - 2nd thing.
    everything else is clean.
  5. Dec 14, 2011 at 11:50 AM
    michaelw
    michaelw New Member
    Michael
    Kennewick, WA
    96 Xtracab 2.4L 5sp 2wd
    Aussie Locker, spray-in bedliner
    I just bought my first Tacoma; 1996 with 94K on it. It has the same 1st-2nd problem. It is particularly bad when cold. I'm thinking of replacing the gear oil with a full synthetic to see if it helps. My clutch disengages at the very bottom and so I'm going to try a pedal adjustment - I like the clutch at the top anyway.
  6. Dec 14, 2011 at 12:13 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    It didnt. I replaced mine with redline synthetic mt90 and it still happens.
    for the OP- just start with the cheapest methods of trying to fix it, or get it to a point where you can deal with it. sounds like it might be a little different from this 1-2 problem.
  7. Dec 14, 2011 at 2:27 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Same on getting into 1st, have to almost give it a little wiggle and a lot of push to try and ease it in like a gentleman. Also experience the "clunk" between 1st and 2nd, but that seems to only happen above 2,000 rpm, which i try to shift out of 1st under anyway.
    Oddly enough it seems like this happens more after switching to amsoil synthetic. Truck has 65,000 on it and put synthetic in about 7,000 ago.
    Subed in for info.
  8. Dec 15, 2011 at 9:46 AM
    cmm275
    Northern California
    2019 TRD Off-Road
    Okay. For now I might start by bleeding the clutch master and adjusting the clutch pedal play because it does engage low. And maybe change the tranny fluid. And cross my fingers in the meantime that it's not the synchros.
    I will let you guys know if any of it helps.
    Anyone else feel free to keep posting if you know anything more about this.
    Thanks.
  9. Dec 15, 2011 at 1:21 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    heh?
    where? what?
  10. Dec 15, 2011 at 2:26 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Does it grind going into reverse also? If it does is the clutch not fully releasing any thing from hyd's to a bad pressure plate, the chance of having 5 bad syncros all at once is pretty slim. The little bushing is easy to knock off if you have had the shifter out but you would feel the slop in the shifter.
  11. Dec 15, 2011 at 2:34 PM
    Tacos Por Vida
    Tacos Por Vida Well-Known Member
    Dominick
    Albuquerque, NM
    97 Taco
    3-inch revtek spacers 265/75 BFG AT Flowmaster exhaust K&N CAI 12'' Type R w/ 1000w amp pioneer cd deck tinted windows
    My 1st gen was having a similar problem, it was hard to get into 1st and reverse. All the other gears were fine. I replaced the master cylinder it's not that hard and only cost like $25 plus the fluid. For the most part it shifts a lot smoother but once in awhile it still has trouble getting into 1st. If you're gonna bleed the master cylinder you might as well just replace it. It should only take a few hours and the hardest part is getting to the bolts. There isn't much room where it is located so you might have to unbolt and move the vacuum box that is in front of it. But other than that its a pretty straight forward installation. Although on mine (i drive a 97) the end piece on the rod of the replacement master cylinder was too fat to fit in the hole(that's what she said :D, ha beat all you guys to it), so i had to unscrew the old one and put it on the new one. Not sure if you'll have the same problem. Just make sure you have a buddy for bleeding the cylinder.
  12. Dec 15, 2011 at 2:42 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Possibly three problems,
    Clutch master and slave units.
    Heavy fluid in the transmission--is it more difficult w/cold weather. May need to have it changed.
    Syncros-Possible -not likely-IMO-
    Not familiar w/ the plastic thing they are refering to==at the shifter.
    CHECK THE EASY stuff first--
    If you replace the clutch master cyl--do the slave TOO--just a matter of time for the slave..Save you some time later.
    Rebuild kits may be available from NAPA or Toyota--you can check.
    TacomaJunkie8691 likes this.
  13. Dec 15, 2011 at 2:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Other than hydraulics being suspect some more aspects are worn friction disk(can probably rule out if no slipping is occuring) weak pressure plate springs (even if no slipping, can cause dificulty engaging) & the throw out bearing (prolly the first part to start failing) dont know if this helps or not but its some other things to consider
    I'd rule out bad synchros
  14. Dec 15, 2011 at 2:56 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Yep, that would be the first place that I would look.
    Then the slave.
    First make sure that there is no air in the system.
    When they are failing, they usually leak. The level drops and they suck in air.
    These often wear at similar rates. If you replace one the other will soon follow.
  15. Dec 15, 2011 at 5:26 PM
    michaelw
    michaelw New Member
    Michael
    Kennewick, WA
    So I adjusted my pedal, and while I'm sure it helped smooth out my clutch engagements due to preference, I can't objectively determine if it really changed anything.
    The temperature was somewhat warmer, so it wasn't as bad. But 1st pretty much always feels like I'm pushing against an immovable object until it just suddenly pops into gear. While second feels mostly normal, but only after warmup. Not much grinding, though I occasionally have minor grinding in other gears, even with the clutch fully depressed.
    It doesn't seem like the clutch is dragging at all with the pedal fully depressed, so I'm skeptical as to if any of this is a master/slave cylinder issue. It might be as simple as changing the fluid, which I'm sure needs to be changed anyway - I haven't yet completed the obligatory new used vehicle fluid change routine. I'll start simple and go from there. If anything works I'll post it.
  16. Dec 15, 2011 at 7:07 PM
    cmm275
    Northern California
    2019 TRD Off-Road
    Thanks everyone for responding. Definitely a lot of helpful information that I can use as a starting point.
    That bushing actually could be a possibility as the stick does have a lot of play and vibrates around a lot when in gear...
    Glad that everyone seems to be ruling out the synchros because I would much rather replace the whole clutch than the tranny.
    Now its time to get to work and see what helps.
  17. Dec 15, 2011 at 9:05 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Regarding the second to first gear selection. Give it a very slight bit of gas while you are making the transition and it should be a lot smoother of a shift and not feel like you are having to force it in as much.
  18. Jan 24, 2012 at 4:03 PM
    cmm275
    Northern California
    2019 TRD Off-Road
    Not sure if anyone will read this post now since I'm writing it so much later... but I have done some work to try to solve my problem.
    1. Checked clutch master and slave for leaking fluid - none
    2. Bled clutch hydraulics - helped with clutch play but didn't help shifting
    3. Checked bushing at end of stick - looks fine, also greased it
    4. Replaced Tranny fluid - helped a little
    However, the gears are still difficult to engage. Fourth being the hardest, then third, then first, then second. Fifth seems to be the easiest. Sorta leaning back to transmission and synchro problems at this point. At a stop, when the clutch is first depressed, it is difficult to engage a gear. But if I wait a few seconds for the countershaft to stop spinning (without shifting), it will slide right into gear. My thought being that the synchros aren't matching up the input and output shaft speeds. Or could it just take a few seconds for the clutch to free up?... I don't know.
    Revving the engine with the clutch depressed during normal shifting actually does help a lot too. Have no clue why that would be as the tranny should be free from the engine at that point.
    Any further input would be much appreciated.
  19. Jan 24, 2012 at 9:03 PM
    thatSchusterguy
    thatSchusterguy Well-Known Member
    Cincinnati, OH
    96 X-Cab
    OME/881 Dakars Demello HD sliders Marlin 1200# Clutch Rust and Duct Tape
    I had the same issues as everyone describes, replaced the slave and it felt better for maybe a day or 2 before it went back to the same old symptoms. I had a new marlin clutch installed about 10k ago and it seems to be holding up fine so that shouldn't be an issue.
    Granny shifting and/or double clutching like you should seems to help, but maybe I'll look into replacing the master once it warms up.
  20. Apr 4, 2012 at 1:48 PM
    arif
    arif Member
    Adam
    Washington, New Zealand, Mammoth Lakes, Ca
    Silver 04 v6 access cab 4X4 SR5
    Just put a new clutch in my truck about 3k ago and still has similar issues as people have described. I did not do the syncros though. Makes me think it might be more of a syncro issue. Just my 2 cents worth.
