Bad CV axle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBourque, Feb 25, 2024.
  1. Feb 25, 2024 at 5:12 AM
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Noticed a vibration at low speeds especially turning this morning. Sure enough the passenger CV is leaking. How bad is this to drive on? Got an appointment with the mechanic on Thur.
  2. Feb 25, 2024 at 5:18 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Small leak isnt the end of the world, but vibrations are not a good sign. Maybe its been leaking a long time. Few more days wont kill it most likely.
    If its the OEM CV axle, and turns out to be in good shape, have your guys reboot it with OEM boots/lube. Or at least request to keep it. Aftermarket part-store CV axles suck...go bad way more quickly than OEM...more prone to vibrations, ect.
    Salmonloaf likes this.
  3. Feb 25, 2024 at 5:26 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    If you end up needing a new CV axle, your options are aftermarket (don't do it,) Toyota original (good, but very $$$,) or a quality remanufactured CV.
    These guys have been around quite awhile and seem to be trusted on TW:
    https://www.cvjreman.com/product-tag/9808/
    303tacoma and wilcam47 like this.
  4. Feb 25, 2024 at 5:59 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    To me that sounds like a wheel bearing.
    A cv axle leaking some grease is not a big deal, plus when going bad they click..
  5. Feb 25, 2024 at 7:35 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    All of a sudden though?
    303tacoma[QUOTED] likes this.
  6. Feb 25, 2024 at 7:50 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I’ve been driving on mine for months both inner boots are bad :anonymous:. Getting them both replaced along with the lower ball joints Thursday.
    303tacoma likes this.
  7. Feb 25, 2024 at 7:53 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    The vibration all of a sudden concerns me
  8. Feb 25, 2024 at 8:07 AM
    303tacoma
    Rebecca
    Ya thats how it happens:D
  9. Feb 25, 2024 at 8:14 AM
    DoubleB
    DoubleB Well-Known Member
    Bakersfield CA
    22 TRD Pro / 06 PreRunner
    Cv axels are easy to swap out and not too pricy. About $110 each side from Rockauto. My son and I did the ones on his 2000 Tundra in about 1 1/2 hours. We had to go aftermarket since Toyota has stopped making them for first gen Tundras. I agree with getting OEM if you can. I tried to buy OEM and shelled out $900 only to be emailed a day later saying the were on permanent backorder, aka discontinued.
  10. Feb 25, 2024 at 8:15 AM
    Salmonloaf
    Salmonloaf Well-Known Member
    Cameron
    Alaska
    2006 SWB AC OR
    as mentioned i would highly recommend going with OEM. i replaced my passenger side less than 2 years ago with a NAPA one to save a penny. new one is already leaking.. went back to OEM, cost $552. buy once, cry once i guess. the quality of the toyota axle really is noticeable though.
  11. Feb 25, 2024 at 8:23 AM
    303tacoma
    Rebecca
    Do you feel the vibration in the steering wheel or the seat of your pants??
    steering wheel is something up front
    Like wheel bearing /wheel balance/
    needle bearing is usually a whining not a vibration.
    seat of your pants is something rear end
    Like a carrier bearing/ driveline u joint
    Just some ideas
    Marc70 likes this.
  12. Feb 25, 2024 at 10:05 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I too agree that OEM is absolutely the way to fly here - if you can afford a new one or find an OEM remanufactured one. As for remanufactured CV's in general, you have to be careful there. If the core they start with is OEM, you have a decent shot at success. If the core they start with is aftermarket, you're screwed. You will not get an aftermarket remanufactured CV (with a Toyota part number) from your Toyota dealer. They always start with Toyota cores.
  13. Feb 25, 2024 at 10:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Look for OEM reman. Like a remanufactured one that the dealer would install. I've used them on bigger trucks like Sequoia and older tundra. Not sure about availability for a Tacoma but it's worth asking
  14. Feb 25, 2024 at 11:05 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Whole truck vibrates really. Only happens when I’m turning slowly less than 20 mph mostly when I’m turning left
  15. Feb 25, 2024 at 11:07 AM
    jjgandarillas
    jjgandarillas Well-Known Member
    joseph
    Anc, AK
    SPORT DCSB MT
    ICON 2.5 VSRR, icon 2.0 ext travel, UCA’s, Ray 10 17x8.5 -12, 285/70r17 BFG Ko2
    While you’re down there feel the play in the driver side CV axle, there’s a small chance it could be your needle bearing needs replaced by the ECGS. check to see if the vibration goes away in 4wd. I also agree that the passenger side CV boot should be addressed but that might not be what’s causing the vibration
  16. Feb 25, 2024 at 11:11 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    I already have the ECGS bearing
  17. Feb 25, 2024 at 11:40 AM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Anybody had any luck getting OEM axles recently, last time I talked to the dealer they were backordered for months
  18. Feb 25, 2024 at 12:22 PM
    303tacoma
    Rebecca
    Cvj remans oem reman only
    Too Stroked and RadRed06[QUOTED] like this.
  19. Feb 25, 2024 at 12:24 PM
    303tacoma
    Rebecca
    Hmmm my vote is still with a wheel bearing..:notsure:
    Hopefully you appt Thursday will be helpful
  20. Feb 25, 2024 at 12:36 PM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I will say this while I’ve been driving for a few months on two bad inner boots with no noise/vibration issues what so ever when the outter boots went out on my 2003 it didn’t take long for it to start making noises and vibrations.
