Bad dealership first oil change experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Herbaltaco, Mar 25, 2014.
  1. Mar 25, 2014 at 3:42 PM
    Herbaltaco
    Herbaltaco [OP] Active Member
    Ventura Co. CA
    2014 Tacoma TRD Sport DCSB 4x4,94Toy pick up
    Window tinting, Husky Liner Floor Mats, Ultra gauge, Wet Akole seat covers ordered lol.
    So I have 4000 miles on my 2014 Toyota Tacoma DCSB 4 x 4. Figured it was a good time to go get my first free oil change. Was told by the dealer where I bought my truck that the first two oil changes are free. I told him that didn't mean much to me because I change my own oil. He said, "well you might as well use it because synthetic oil is not cheap and that is what your Tacoma takes."
    Since I bought my truck at a dealership 40 minutes from my house, I decided to go to my local dealership for the oil change. I called them first to see if I was okay, and they said no problem. I set up an appointment.
    When I arrived for my oil change, the guy that comes out to set you up started taking down my information. I asked him if this was going to be a free oil change. He said, let me check to see if this truck takes synthetic or conventional oil, I will be right back. He returned and said yes it will be free this truck takes conventional oil. I said no it doesn't, it comes from the factory with synthetic, and that's what I want. He said well let me go back and check. He came back and said no it takes conventional. I was pissed and said well if you don't know that this truck is supposed to take synthetic, I'm not leaving my truck with you.
    Guess I'm out the money I already paid (of course it's worked into the price of the truck) for the 2 free oil changes because I'll never go back there again.
    Anyone know the deal with this situation? Are they supposed to give you synthetic for free on the first two oil changes?
  2. Mar 25, 2014 at 3:46 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do your own oil changes (and lube the driveshaft u-joints while you're at it)
  3. Mar 25, 2014 at 3:49 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Don't believe anything that the salesman tells you. Read the owners manual instead. Lot's of good information in there.
  4. Mar 25, 2014 at 3:50 PM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I have the same truck. The manufacturer puts regular oil in it.
    Personally, I will be going to the dealer and asking for a free filter and doing my own changes with Mobil 1.
    You may want to educate yourself on oil. I did so by reading this: http://www.bobistheoilguy.com/motor-oil-101/
  5. Mar 25, 2014 at 3:53 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I never heard of any Tacomas coming with synthetic oil from the factory and I was always told it was just conventional. I think your first dealership you bought the truck was wrong.
  6. Mar 25, 2014 at 3:53 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    The dealership was correct. The 4.0 comes with conventional oil. Here is a chart.
    http://www.settraining.com/content/course-codes/12_07_HS_Toyota_Engines_and_Synthetic_Oil1.pdf
  7. Mar 25, 2014 at 4:00 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Judgeing by the many threads here of dealership oil change mishaps you might have done yourself a hugh favor by not letting them do it.
  8. Mar 25, 2014 at 4:07 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    At my 5000 mile oil change .... The truck (2013 TRD 6 cyl) came with regular oil ... I paid the difference in price from regular to synthetic and the dealer put in synthetic with a new filter . Simple .. and Fair .
  9. Mar 25, 2014 at 4:36 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    It's in the manual. :evil:
    You can't get upset with the service department on this one.
    Hunt down that salesman.
  10. Mar 25, 2014 at 4:47 PM
    MariettaTaco
    MariettaTaco Well-Known Member
    Scott
    Marietta, GA
    2013 Superwhite 4x4 Dblcb
    I thought it was 2 years of free maintenance. What's this about the first two oil changes? Has Toyota done away with the 2 year free maintenance thing?
  11. Mar 25, 2014 at 4:49 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    They still have the 2 yr toyotacare going here.
  12. Mar 25, 2014 at 4:52 PM
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    The 6 cyl actually comes with a synthetic blend, which is rated conventional. Was just at a dealer the other day talking with a guy holding repair paperwork. Seems the day previous the dealer erroneously put 0-20w in his 6 cylinder for the 5k oil change. I am from out-of-town visiting .. .. .. not a confidence builder!
  13. Mar 25, 2014 at 5:00 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    He got a free upgrade and wanted to downgrade:confused:
  14. Mar 25, 2014 at 5:25 PM
    Herbaltaco
    Ventura Co. CA
    So I guess the guy at the dealership service department at T.O. Toyota was correct and I was fed even more BS from my salesperson at Ventura Toyota than I knew. My buying experience with that dealership was bad. Will never go back there either.
    I'm very anal about my expensive toys so I only use the best. Going to go synthetic and do it myself. That is the only way I feel confident that I am actually getting what I pay for. When I get my Subie done at the dealership I wonder if they are really putting synthetic in there. The ground clearance difference and filter placement on the Yota make it night and day easier to change the oil than on the WRX.
    Any good recommendations for honest oil change places I can take the Subie other than the dealership?
    Thanks for the responses all who replied. Appreciate your input.
  15. Mar 25, 2014 at 5:37 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    ^^^This.
    Plus I'm old enough and experienced enough to know that (other) people just don't take the same care with your shit as you. I take meticulous care of my tools and vehicles and unless its something out of my realm of knowledge and expertise, I'll do it myself.
  16. Mar 25, 2014 at 5:39 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    At the Ford dealership I work at has the customer pay the difference between conventional and full synthetic if the customer requests full synthetic. last week a customer brought in his new F250 for his first time oil change and he requested the full synthetic upgrade. The difference was 147 bucks between conventional and synthetic. On a side note, the Mustang GT 500 is the only production vehicle from Ford that gets full synthetic from the factory which is 5w50.
    Sounds like the OP needs to read his owners manual lol..
  17. Mar 25, 2014 at 5:50 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    He could also let the dealership know, he was the one who made the mistake. Respect goes both ways. ;)
    Frank
  18. Mar 25, 2014 at 5:51 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Hadn't thought of that. I got two free years of Toyotacare, but have been changing my own. I'm gonna see if my stealership will give me a filter.
  19. Mar 25, 2014 at 7:34 PM
    craigb
    craigb Well-Known Member
    Craig
    Pa
    2013 TRD Sport
    Leer Cap Bilstein Shocks under bed lighting all weather mats window rain guards bed mat
    It's tells you on the oil cap. How hard is that. I thought it was 2 years free service for any Toyota that you buy new or 25,000 miles. Mine was free and no hassles. Even got free soda and snacks.
  20. Mar 25, 2014 at 7:44 PM
    gasgasman
    gasgasman Well-Known Member
    Girard
    Texas
    Yup.
    People always getting pissed for no reason.:confused::confused:
