Bad design Toyota! Water leak expected. WTF! Recall... oh sorry TSB!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w8n4mud, Feb 10, 2010.
  1. Jul 2, 2013 at 8:13 AM
    #161
    Eternal24k
    Eternal24k Well-Known Member
    Vermont
    2009 SR5 V6 4x4
    Yep, same.
    Would still love some pics
  2. Dec 16, 2013 at 4:19 PM
    #162
    Alex Segal
    Alex Segal Member
    North Florida
    09 Tacoma Dcab longbed
    scanguage II,prodigy3 brake controller, softopper
    Just gets wet in the middle of the footwell. Sides and cabin filter dry. Wish W8N4Mud would repost!
  3. Dec 16, 2013 at 6:05 PM
    #163
    w8n4mud
    w8n4mud [OP] I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    You've given me a project. However with that being said, just make sure your cowl is either set in correctly or that you aren't missing any plastic molding pieces. Mine didn't look bad and I couldn't tell anything different from the replacement part from the junkyard other than it sat better against the windshield. If your cabin air filter is not wet, there's a good chance it may not be related. I'll try to recreate or look at my old pictures to see if I have them. Sorry to hear about the leak. It definitely sucks to have the interior wet. Kinda hopeless feeling unless its garaged.
  4. Dec 17, 2013 at 9:29 AM
    #164
    Alex Segal
    Alex Segal Member
    North Florida
    When I pour water down the windshield onto the cowl, it goes down into the engine compartment and runs down the firewall seemingly at random. I've 'plumbed' the apparent drain holes and cleared out a lot of trash & leaves, but the wetness persists.
    I just gave up and took it in. The TSB replacement cowl fix is $400 if off warranty (I am), but if they really fix it I'll bite the bullet.
    Thanks for any info, W8N4MUD!
    ps your build is awesome
  5. Jan 1, 2014 at 2:20 PM
    #165
    Alex Segal
    Alex Segal Member
    North Florida
    OK so I did the $400+ TSB for leak. Just tried it out this week in a famous Florida rainstorm- still leaking and this time had wetness on drivers side as well!
    Taking it back in, can't wait to hear what abba-dabba excuse they give me for this!
  6. Jan 1, 2014 at 4:08 PM
    #166
    RBaptist
    RBaptist Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    I was looking on the forum for something else, but stumbled on this. One thing to check would be to make sure the vent is closing properly on the passenger side. where the cabin air filter is installed. A while back in a rain storm I had water coming in under the dash. Turns out - the cabin air filter got jammed in the door the closes when you switch between recirc/vent. I think something also changes over between heat and A/C but can't recall. The filter kept the door open and water wasn't diverting properly. Thought it might help someone.
  7. Jan 1, 2014 at 5:29 PM
    #167
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Water should never come in above the filter regardless of doors/flaps and their positions.
  8. Jan 11, 2014 at 2:15 PM
    #168
    Alex Segal
    Alex Segal Member
    North Florida
    Dealership wants to replace rear window, not reseal, replace- to the tune of $1200. Alleging THAT will fix the leak.
  9. Jan 11, 2014 at 3:54 PM
    #169
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT
    As usual... just here for the boobs.
  10. Jan 11, 2014 at 7:46 PM
    #170
    andrea
    andrea Member
    andrea
    indiana
    06 SR5
    I had the same problem with my 08 highlander
  11. Sep 15, 2015 at 1:18 PM
    #171
    SurfnSwdsman
    SurfnSwdsman Member
    2007 Tacoma V6 TRD Off Road 4X4
    I got a 2007 TRD Offroad 4x4 Access Cab in May. It's used and had 100k on it but it's been working great and I've been enjoying driving it. It rained pretty hard last night in SoCal and I found a small puddle of water on my all weather floor mat when I opened the door to my truck this morning. I saw some droplets still dripping from under the AC blower. I checked the cabin air filter and it wasn't wet. Any idea how the water got in and solution to this?
    I read through the OP post all the pages but didn't the see the pics or definitive solution.
    Thanks for the help!
  12. Sep 15, 2015 at 1:44 PM
    #172
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Necro post
  13. Nov 30, 2015 at 12:14 PM
    #173
    jeffro2058
    jeffro2058 New Member
    Other than pulling the carpet, what are people finding the best solution for getting rid of the sour musty smell from water on the floor carpet?
  14. Nov 30, 2015 at 1:36 PM
    #174
    SurfnSwdsman
    SurfnSwdsman Member
    I used Biokleen Bac-Out Stain and Odor Eliminator. Use paper towel to blot out as much water as you can before using Bac-Out. I removed the floor mat on the passenger side and let it air out as much as I can. After the a few weeks of scorching weather here in SoCal. The smell and dampness went away. I replaced the cowl grille and no leak detected from the last rain.
  15. Dec 23, 2015 at 6:02 PM
    #175
    tacomaguy2012
    tacomaguy2012 New Member
    2012 tacoma access cab 4 cyl 5 spd
    1.25 wheel spaces trd alloy wheels 285 70 R17 nitto MT and 2 inch spacer lift kit
  16. Dec 23, 2015 at 6:06 PM
    #176
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    Bring the Hilux!
  17. Feb 23, 2016 at 1:36 AM
    #177
    sekerbs
    sekerbs Member
    '07 Silver Tacoma Extra Cab TRD Prerunner
    I have discovered lots of water on the passenger side 3 times after a heavy rain (it probably has happened more; I remember musty smells during past winters but wasn't looking for the problem). After reading this thread, I took off the cowl, took the glovebox and passenger seat out, and lifted the carpet up to dry and try to find where water was coming in. The filter wasn't wet and it didn't look like any water had dripped through that area. I squirted tons of water onto the windshield and into any opening I could find except for the main one that goes to the cabin filter. Did not see a drop appear in the cab anywhere... Since everything was apart, I decided to give the cabin vent opening more protection just in case that is the access point. I didn't want to mess with adhesives so I came up with an easy mod. I took an extra Sterilite container lid I had lying around and cut a piece from it. I attached two metal tabs (old cabinet striker plates) to the two holes on the lip of the vent opening. This was probably unnecessary, but I wanted to make the plastic cover extend further and needed something to attach the cable ties to. I punched two holes in the plastic cover and attached with the cable ties. The top of the cover nests under the windshield and wedges against the firewall; it's not going anywhere, but it is flexible enough to allow the cowl to slide back into position. Hope this fixes the problem, but it sure didn't look like any water had gotten in through there; at least not the volumes I've had on the floorboard... Have no clue what to try if it happens again...20160222_232614.jpg 20160222_232936.jpg 20160222_233128.jpg 20160222_233449.jpg 20160222_234808.jpg
    smw62891 and T@co_Pr3runn3r like this.
  18. Feb 23, 2016 at 2:29 AM
    #178
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nice patio cover. Whether it leaks or not, I'm kinda concerned about an opening just straight into the cab uncovered like that. It's almost like, how can that not leak? Why wouldn't it be covered like this from the factory? Thinkin about doing this to mine even tho I haven't had any wet floorboards.
    sekerbs likes this.
  19. Feb 23, 2016 at 5:23 AM
    #179
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    That cover was a nice idea, but for some reason I was getting exhaust fumes in the cab. While sitting in traffic, found out it never really supposed to close no matter what. It's design to draw a small % of fresh outside air no matter what! I took a piece of cardboard cover the bottom opening, and used a can of construction foam to fill the void.
  20. Feb 23, 2016 at 10:50 AM
    #180
    sekerbs
    sekerbs Member
    That looks like it would keep out fumes, water, and anything else! lol Don't know why exhaust fumes were coming thru there… Possibly a manifold leak?
    NeedmoreTaco likes this.
