Bad Door Lock Actuators?
Discussion in 'Technical Chat' started by Blake, Jan 15, 2012.
  1. Jul 29, 2012 at 1:43 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Lemme know how you make out, I have a dead pass. door lock and I too am looking to fix it cheap.
  2. Jul 29, 2012 at 2:20 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Will do, they should be here shortly and I'll try to tear it apart next weekend.
  3. Aug 4, 2012 at 12:37 PM
    Pugga
    Massachusetts
    The motors I bought off Ebay weren't the correct ones. The motor itself is the same but the output shaft is different which prevents you from inserting it into the actuator unit the same way the old one came out.
    The one I bought off Ebay had a short, round shaft. The one on the truck has a long shaft that is split length-wise (so that when you slide the worm gear onto it, it can't spin freely on the round shaft).
    I kept searching Ebay and I can't seem to find one that fits. If I do, I'll let you know.
  4. Aug 4, 2012 at 4:04 PM
    Neb
    Neb Well-Known Member
    Ben
    Tennessee
    06 PreRunner TRD Sport
    TRD S/C, URD ShortShifter, URD Y-pipe, URD Mk2 Catback, URD 2.8Pulley, URD U-spec headers, Innovate AFR/Boost, AFE Intake
    I had a dead Driver's side door actuator. Took apart the door and pulled out the motor as described in the earlier posts. Cleaned up the contacts in the electric motor, put her back together, and everything is working perfect. Great post; thanks for the info to everyone that contributed!
  5. Aug 22, 2012 at 7:00 AM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Did you take any pictures of the motor and shaft or find any numbers stamped on it. I found another site that has some motors http://store.kysanelectronics.com/servlet/-strse-DC-Motors-cln-Automobiles/Categories
  6. Aug 22, 2012 at 7:09 AM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    I had all 4 doors replaced in my 09 because they all shit the bed.:mad:
    Driver side was first shortly after the pass side did the same.
  7. Aug 22, 2012 at 7:12 AM
    Pugga
    Massachusetts
    I didn't but the motors I bought had the same stamp on them as the OEM ones. The only difference between the motor I bought and the OEM motor was the shaft.
    FC-280PC-22125 Mabuchi Motor was the description. It's the right motor, wrong output shaft.
    I must not have posted back since but I was able to get the actuators working. I tore apart the old motor completely, cleaned out all the carbon buildup using a spray type electrical cleaner and a rag (made by the same company who makes Brakleen, red and white can available at autozone), reassembled and everything works like new.
    From your site:
    http://store.kysanelectronics.com/servlet/-strse-69240/FC-dsh-280PC-dsh-22125/Detail
    It's the correct motor, but again, wrong output shaft.
  8. Sep 28, 2012 at 8:53 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Good thread everyone (bringing it back!). Going to be tackling this in the next week or so. My driver side wet out a few years ago and then started working again, but about 5 months ago it stopped. Will pop it open and give it a good clean.
    Is there a way to seal the actuator up so no more dirtyness inside? Did any of you slather dielectric grease inside?
  9. Sep 28, 2012 at 9:17 AM
    Pugga
    Massachusetts
    The dirtiness is coming from inside the motor so sealing it up won't help. I did not slather on dielectric grease but mine are working fine again after tearing the motor down and giving it a good cleaning with CRC Electric Cleaner.
  10. Dec 5, 2012 at 12:18 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Bringing this one back-
    Well I went to pull my drivers side lock actuator out to see if I could clean it up and get it to work again, but......
    I lined my doors with sound deadner a couple of years ago when i did my stereo install and I covered any access to the lock actuator. I wasn't about to go ripping off the butyl rattle trap I used so I'm going to have to live with a manual driver side door lock.
    Just FYI for any of you that's going to install sound deadener on your doors. If you gotta get to the inside of your door your in for pain in the ass work..
    hazard2600 likes this.
  11. Dec 5, 2012 at 12:21 PM
    RichieW13
    RichieW13 Well-Known Member
    Richie
    Thousand Oaks, CA
    2008 PreRunner Sport
    7 months later, the left rear door has stopped working.
    My truck is 4-5 years old, and has about 50,000 miles on it. It sure seems like this should work longer.
    The worst thing about newer cars with all the bells and whistles (automatic windows, heated seats, keyless entry, etc.) is that all of these things seem to quit working at some point.
  12. Dec 5, 2012 at 12:46 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    It has to be that toyota is using inferior parts now days. However, I think door lock actuators in general seem to go quickly. Unfortunately, besides opening up the non working actuator and trying to fix it there is no cheap aftermarket option. $220 for a replacement one is ridiculous. We should see if we can find a company here in the US that can make an aftermarket actuator that will fit our trucks, get a group buy going, cuz I'm sure a lot of people would jump on this.
  13. Dec 5, 2012 at 12:52 PM
    RichieW13
    Richie
    Thousand Oaks, CA
    I don't think Toyota is the only perpetrator. My Grand Cherokee had the heated seats go out, and also had the same door lock problem. Although with that one it was the actual motor that went bad and had to be replaced.
  14. Dec 5, 2012 at 1:28 PM
    Pugga
    Massachusetts
    Why would people jump on a group buy? If someone is going to go through the hassle of tearing open the door to pull the actuator out, they might as well spend an extra 5 minutes to clean up the motor and have it work like new for free rather than replace the part. The hardest part is getting damned thing out of the door! At least for me it was, I have fat hands. :eek:
  15. Dec 5, 2012 at 1:35 PM
    #35
    RichieW13
    Richie
    Thousand Oaks, CA
    Yeah, taking it out is a pain - especially dealing with the vapor liner. But cracking the mechanism open and cleaning it and getting the linkage together isn't the easiest thing either.
  16. Dec 5, 2012 at 2:59 PM
    #36
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    subbed for future reference and fucking around with:D
  17. Dec 16, 2012 at 4:49 PM
    #37
    kwade
    kwade Member
    kwade
    sc
    08 taco DC
    My 08 front driver door lock actuator started failing a couple weeks ago.
    I took it out and partially disassembled it yesterday.
    The small clips around the edges were the worst part. My fingernails are still separated from my fingers.
    I didn't want to remove the motor from the assembly without doing some research first. I did notice some darkening inside the commutator/brush end of the motor.
    I reinstalled the assembly. I will wait until next weekend to attempt motor removal and cleaning.
    Questions:
    On the 08 actuator, is the motor soldered or does it simply pull out of the assembly? I will know this coming weekend - barring more rain.
    The white grease inside the actuator, is it a lithium-based grease?
  18. Dec 16, 2012 at 5:17 PM
    #38
    Pugga
    Massachusetts
    Get a pick set from Harbor Freight, Sears or any other store that sells tools. They make pulling the motor apart much easier.
    On my 2007, the motor is not soldered in. I'd imagine it's the same on your 2008. As far as the grease, I didn't mess with it, I just put everything back together and called it a day.
  19. Dec 16, 2012 at 6:17 PM
    #39
    RichieW13
    Richie
    Thousand Oaks, CA
    Oh yeah, I remember that. My fingertips hurt for 2 days.
  20. Dec 16, 2012 at 8:03 PM
    #40
    othater
    othater Well-Known Member
    SoCal-Walnut
    06 Prerunner SR5 TRD Sport
    My actuators are working but I had the same issue with 06 Lexus GS.
    ClubLexus has a write up also.
    http://www.clublexus.com/forums/gs-second-generation/289839-door-lock-acutuators-diy.html
    What I ended up was opening up the motor, cleaning and swapping the guts out with the new motor.
    All the black carbon was worn out so it wasn't making a good contact.
    The gear on the shaft is suggest to get a RC gear puller to remove and replace on the new shaft which I didn't have.
    Been working for the last four years.
