Bad Driver CV or ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpeySquatch, Jun 10, 2018.
  1. Jun 10, 2018 at 6:58 PM
    SpeySquatch
    SpeySquatch [OP] Function over Form
    2016 TRD OR DCSB
    got a vibe that occurs even though I have shims (second set) and ECGS bushing needle bearing replacement.
    Vibe is 38-45mph.
    Could this vibe be harmonic engine vibration or bad cv if it not the driveline? My driveline angles are perfect.
    What does a bad cv feel like?
  2. Jun 10, 2018 at 7:07 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    remove shims?
  3. Jun 10, 2018 at 7:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Highly doubt it's your CVs themselves. How are you sure your angles are perfect?
  4. Jun 10, 2018 at 7:11 PM
    SpeySquatch
    2016 TRD OR DCSB
    Drive differently, but worse with no shims. Vibe has always been there
  5. Jun 10, 2018 at 7:12 PM
    SpeySquatch
    2016 TRD OR DCSB
    Measured 4 times. Have 3 degree shims.
    Working angles were .02 degrees different with no CB spacer
  6. Jun 10, 2018 at 7:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Where do you feel the vibe? Seat, pedal, steering wheel, etc?
  7. Jun 10, 2018 at 7:14 PM
    SpeySquatch
    2016 TRD OR DCSB
    Top of the steering wheel and in floor slightly. Slightly feel in brake pedal when braking. Vibe even occurs in coast coming down thru speed range.
  8. Jun 10, 2018 at 7:14 PM
    blackohio
    Cliche Guevara
    white mudflap
    i’ve seen more than a few shim vine posts. typically remedied by removing shims
    you sure the rear end is aligned correctly. i’ve seen posts where centering pin holes were off center before
  9. Jun 10, 2018 at 7:15 PM
    SpeySquatch
    2016 TRD OR DCSB
    Hmm I could try it. I recently got a leaf removed and the vibe is still there as well although slightly less after the leaf removal
  10. Jun 10, 2018 at 7:19 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    You had the ECGS bushing replaced but have you tried that speed in straight line with 4wd engaged to see if it goes away? Just a thought to try.
  11. Jun 10, 2018 at 7:21 PM
    SpeySquatch
    2016 TRD OR DCSB
    Vibe is still there in 4wd but 1/2 as aggressive, maybe 1/3
    20tacoma17[QUOTED] likes this.
  12. Jun 10, 2018 at 7:21 PM
    Bishop84
    Bishop84 Well-Known Member
    Even with the ECGS the vibes will still be there, it's the nature of the axle binding.
    My did it about 80% less after the ECGS but better.
  13. Jun 10, 2018 at 9:49 PM
    SpeySquatch
    2016 TRD OR DCSB
    So...is there a way to get rid of it? Many people report no vibes. My vibe is parabolic and harmonic in nature.
  14. Jun 10, 2018 at 11:34 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Have you tried putting a different set of rims and tires on to see if that changes anything? That’ll eliminate balance and tire wear from the equation if the shimmy still exists after rim/tire swap. If the shimmy disappears then you found the culprit.
  15. Jun 11, 2018 at 2:24 AM
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    I forget the thread name but a guy put together a set of locking hubs and that enables you to disconnect the front driveline to eliminate vibe. Bonus is better mpg without the parasitic loss into front drivetrain. Also enables you to have a 2lo if you put it in 4lo with the hubs unlocked. You can leave the ADD system intact so no worries there.
    scottalot likes this.
  16. Jun 11, 2018 at 2:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @05Taco4x4 is the guy that made that
    scottalot and 05Taco4x4 like this.
  17. Jun 11, 2018 at 6:48 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Carrier bearing shims. Have you tried that?? I had a vibration similar to yours after 2" lift and it went away after carrier bearing shim add. Can try a few washers to see if it works for ya before spending $10 on shims.
  18. Jun 11, 2018 at 7:30 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    +1 to this. You are running a full Dakar pack, and for me, I had to put in both 3 degree axle shims and carrier bearing drop to get the angles right and eliminate vibration from it.
  19. Jun 11, 2018 at 10:18 AM
    SpeySquatch
    2016 TRD OR DCSB
    Definitely want to do this, just need access to a different set of rims and tires
    inksin[QUOTED] and scottalot like this.
  20. Jun 11, 2018 at 10:19 AM
    SpeySquatch
    2016 TRD OR DCSB
    I have 3 degree shims with no CB spacer. I’ve read that no space for the CB should be used if you can accomplish ideal working angles in the driveline. My working angles are .2 degrees different which is nothing
