Bad driver side CV axle but boots are fine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ricco333, Apr 26, 2025.
  1. Apr 26, 2025 at 10:01 AM
    ricco333
    ricco333 [OP] Active Member
    Erik
    2021 White SR5/4x4
    Hi, I'm getting the grinding noise from my front driver side when I turn to the left and also when slow braking, it sounds just like a front wheel drive car with bad CV joints.
    The boots are perfectly fine, they look brand new, I think is the driver's side CV axle, the ECGS has been done since I thought it was that at first. Has anyone experienced something similar? What's a good replacement aftermarket axle, and also do I have to replace both of them or just the one that failed?
    Thanks.
    Erik
  2. Apr 26, 2025 at 11:45 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Are you past 60k? Bad CV axle should be covered under the powertrain warranty.
    Replacing just the failed side is fine.
    ricco333[QUOTED][OP] likes this.
  3. Apr 26, 2025 at 1:08 PM
    ricco333
    Erik
    2021 White SR5/4x4
    Will they honor the warranty even if lifted? I have to call the dealer and speak to an advisor. I just hit 30K
  4. Apr 26, 2025 at 1:25 PM
    yotadust
    yotadust Well-Known Member
    No they will use that as an excuse
    Ricardo13x likes this.
  5. Apr 26, 2025 at 1:25 PM
    yotadust
    Do you have the parts to put it back to stock real quick
  6. Apr 26, 2025 at 1:29 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Bad wheel bearing?
  7. Apr 26, 2025 at 1:33 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    This^^^ If cv’s seize it’s not grinding noise but a crack, pop and lacka lacka lacka sounds.
    shakerhood[QUOTED] likes this.
  8. Apr 26, 2025 at 1:59 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    There is nothing at the wheel side that could break up without noticing it at the boot. The outer joint is mechanically locked to the hub and the hub is locked to the wheel. The inner birf joint has 6 ball bearings in a cage. If you broke that cage then you would
    see the boot twisted.
    Your wheel bearing is dead. Leave your CV alone.
  9. Apr 26, 2025 at 2:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Depends on the dealer and the specific tech working it. You tell them you have a grinding noise (or whatever you hear) and let them diagnose it. Both the CV and wheel bearing would be under the powertrain warranty if either happens to be the culprit.
    From your post last month, check for a bent brake rotor dust shield.
  10. Apr 26, 2025 at 2:32 PM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    Make sure the rotor guard is not touching or super close to the rotor, I’ve had that happen a time or two.
    Chew likes this.
