bad experience going to 5100's in front
Discussion in 'Suspension' started by commtrd, Jun 14, 2009.
  1. Jun 14, 2009 at 2:19 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    I got my front end all took apart and took apart the first strut (stock shock / spring). I found out that the new shocks should have included new bottom spring perches. No one ever mentioned that in any of the writeups... Also the sway bar is a total pain in the ass. It completely gets in the way and just undoing the mounting point on the spindle IS NOT ENOUGH! I had to undo the rubber bushed mounts under the frame in front to get that POS out of the way enough to get the stock shocks / springs out. Then I went to take the first strut apart and go back with the new shock and discovered that the stock bottom spring perch will not fit. I was fucking pissed. I busted my ass all morning fighting with this and then had no choice to put it all back together again WITH THE STOCK SHIT I JUST TOOK OUT!
    Thanks to DownSouth Motorsports. Yall really slipped me the chorizo on this one. Anyway if anyone is thinking about doing this on your own, think twice about doing it. It's not as easy as they say it is. I am pretty sure that when I get the parts to finish the job I am going to take it to a shop and they can do the alignment on it there. Also having a good close look at things while apart, I have to say that it looks like maybe not too advisable to go with any more than three slots up on the 5100's for the spring preload. The drive angles (CV boots etc.) just don't look too good with that much angle to them just my opinion. Probably get flamed for saying that but that's what I see.
    Man that's a lot of work and aggravation only to have to put the stock stuff back in. [​IMG][​IMG][​IMG]
  2. Jun 14, 2009 at 2:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sorry to hear about that, but this sounds like a rare case. Its not hard to do this install.. A couple of things. Always make sure all the parts are included. Different shocks are most allways gonna have lower spring seats for them. If not, they are incomplete. Also, did you have both front wheels off the ground/removed before takeing anything off? That makes a huge difference. There have been a couple cases in which the wntire sway bar has needed to be removed for the propper clearance. Once again, sorry to hear of the problems. :(
  3. Jun 14, 2009 at 2:58 PM
    commtrd
    Corpus Christi TX
    Follow-up on this: Sonny just called me and asked to verify the part numbers on the boxes. So I did and they were the correct parts. So I opened the boxes (ripped them apart and guess what; the lower spring perches were in there. Gosh what a moron! lower perches. But I was not aware of the different size to the shock bodies before starting the job so I just thought the other parts were not included. My bad on that one. So for the record: I screwed up. I am getting the rear shocks on order so when I take it to a shop they can do all four corners and be done with it. Sonny said that he generally recommends that people take the job to a shop where they can deal with the strut re-build safely with the right tools. That was one thing that kind of bothered me about doing this with the strut spring tools I got from O'Reilly Parts...they did not fit cleanly on the coils and I was kind of freaking out about what if that spring comes undone while I am working on it? It's worth whatever to me to take it to get this done because it's a huge pain in the ass.
    Anyways I wanted to erase the bad rap about DownSouthMotorsports. I was a moron and that's all there is to it.
  4. Jun 14, 2009 at 3:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont be hard on yourself. If you ever have any doubts about an install, its much better to let someone else do it. :)
  5. Jun 14, 2009 at 3:16 PM
    commtrd
    Corpus Christi TX
    Yeah good advice...I am a mechanic (process control analytics) by trade working in refineries and petrochemical plants plus have built up engines for hotrods in years past plus motorcycles and generally do all my own work on everything so I was pretty comfortable I could do it OK. So I guess it will depend on if I can find a good shop somewhere around here to do it. If not I may give it a stab again but definitely going to have to find a better way to do those springs.
  6. Jun 14, 2009 at 3:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you can remove everything, then take the springs/shocks to a shop, it would be MUCH cheaper, than having them do everything.
  7. Jun 14, 2009 at 4:29 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Relax.....Have a beer, and have a go at it again.
    It's a learning experience and I'll gaurentee it'll go much smoother the second time around. Seriously, you gotta give yourself a fighting chance before handing it over to someone else to do.
    And seriously...If you find yourself getting frustrated about something, you gotta walk away from it for atleast 5 minutes or more. You'll be amazed at how much better things come together after you've been able to calm down and clear your head.
    Good Luck!!
  8. Jun 14, 2009 at 4:42 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    You can do it. I helped my 17 year old brother install his today. Took us about 3 hours to do. Most of the time spent was struggling with the sway bar so we finally just took it off and then reinstalled it at the end.
  9. Jun 14, 2009 at 4:57 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Definitely don't give up. The one thing I have noticed with my first time installs is they usually take me an entire day (or more) to do what write ups say takes a few hours. However once I am done, I could redo everything in a fraction of the time.
    Chris's advice is best. That the front assembly off of your truck, and that part only to a shop. They will assemble everything for you for cheap, then you can finish up on your own
  10. Jun 14, 2009 at 8:24 PM
    TX Tacoma
    TX Tacoma Fightin Texas Aggie
    Arlington, TX
    It takes a big man to admit when he's wrong. At least that's what I've heard. Personally, I wouldn't know.
  11. Jun 14, 2009 at 8:42 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    At least you attempted the install for yourself. Great job!:thumbsup:
  12. Jun 15, 2009 at 7:06 PM
    commtrd
    Corpus Christi TX
    I will most likely give it a go again when I get the rear shocks in.
  13. Jun 15, 2009 at 7:31 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Go for it! Some times taking a step back really helps. Look at all the experience dissassembling/assembling your own suspension you've gained by messing up!;)
  14. Jun 16, 2009 at 1:45 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    go for it again dude,like chris said its not that hard.sounds like u have some machanical back ground and youll get it.good luck to ya.
  15. Jun 16, 2009 at 3:00 PM
    Shaydog
    Shaydog Got the itch!
    Raincity BC
    08 DblCab 4x4
    OME885's, Toytec Top Plate Spacers, OME N140S, OME N182, TSB AAL's. 265/75R16 Interco TrXus MT's, IGGEE Seat Covers, Bed Mat, Tow Pkg, LEER Legend Cap, Pop-n-Lock, Hi-Lift with custom bed rail mount, Window Vent Visors. Grillcraft, Daystar Driving Lights.
    I know exactly how you're feeling. I just did OME Springs and Shocks all around. First Strut Assembly I put the spring perch upside down. Didn't notice till it was mounted in the truck. Then, for the AAL's I was provided the wrong axle U bolts. Had to reassembly the leafs and drive 20miles to the shop to swap them for the right ones. Then, I took the rearend apart again, and found that I didn't have the TSB Add A leafs. Man, I was so mad, and tired. But in the end I got it all worked out, and I really feel more proud of myself for sticking with it. And my friends all thought I was crazy for attempting it myself.
  16. Jun 16, 2009 at 3:48 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I always remove the sway bar when doing lifts. makes everything easier, and it's only 6 bolts.
    That sucks about not seeing the spring perches though.
  17. Jun 16, 2009 at 8:00 PM
    commtrd
    Corpus Christi TX
    Oh well live and learn...I need to do it myself to help finance the stereo equipment.
  18. Jun 20, 2009 at 8:29 PM
    commtrd
    Corpus Christi TX
    Well now I have 5100's all around. Installed all today. 5100's in front set one notch up from bottom. That leveled the truck and the angles on the front axles went from nearly level to just a slight angle down. Not too excessive at all. The ride is stiffer which is what I wanted. I did rebuild the struts myself using the strut spring compressors from O'Reilly Parts. I really looked the tools over closely and determined they were perfectly safe to use. No problems except when I went to reinstall the sway bar I really had to muscle it over the tie rod ends. Probably best to spot it over the tie rod ends before making up the bolt / nut on the upper ball joint. Anyway it took me about 7 hours to do all four. Really satisfied with the results and the ride. Plus saved almost enough in labor to get a really good start on the Clarus speakers I plan on installing. Talked to Mr Marv last night for an hour and that is the route I plan on taking when I get ready to upgrade sound in the truck.
  19. Jun 21, 2009 at 9:10 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    Glad you got it all sorted out.
  20. Jun 21, 2009 at 10:41 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I'm not the only one who struggled! :bananadance:
