Bad fan clutch ? Hot & Cold movement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razorecko, May 23, 2017.
  1. May 23, 2017 at 9:42 PM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    So im trying to diagnose some issues. When i try to spin my fan either when it is cold overnight or hot right after shutoff it still only rotates 20% of a full rotation. Is this norm because i read it shoukd spin more freely after its heated up vs cold.
  2. May 23, 2017 at 9:49 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    It should spin less freely heated up.
    Do you have a grinding noise when running around the fan area?
    Does it take longer to get to temp than it should?
    Any mpg drop?
  3. May 23, 2017 at 10:06 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Fan should freewheel with a little resistance when cold
  4. May 23, 2017 at 10:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    if it is only rotating 20% you mean 1 of the blades only moves from 12 o'clock to 2-3 oclock? I feel like that would be a problem.. there should be a difference between hot and cold..
  5. May 24, 2017 at 12:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    http://www.aa1car.com/library/cooling_fan_clutch.htm
    Basically this:
    Fan Clutch Trouble Shooting
    Faulty fan clutches can be detected by checking for obvious indications of failure such as:
    Leaking Fluid - oily build up around the bearing or thermal spring
    Bad Bearing - seized, turns rough or has excessive play (more than 1/4” at fan tip)
    Worn Thermal Spring - spring is loose
    Some fan clutches will show no visible indication of a problem yet may still be faulty.
    The following may also indicate a faulty fan clutch
    Fan Spins Excessively - three or more times when hot engine is shut off
    Poor Air Conditioning - at low speed due to excessive high side refrigerant pressures
    Doesn’t engage or “lockup” - fan speed does not increase when engine is hot
    Does not disengage - fan speed does not decrease when engine is cold
    Benny123 and 2009Access4x4 like this.
  6. May 24, 2017 at 5:02 AM
    Razorecko
    Yea mpg is relatively poor. Yes, 1 blade goes fron 12-2,3 o clock. And it turns the same wether hot or cold. Ive been trying to nail down a persistent squeek and a strange and loud "howling noise" , i have a trd blower and power is down greatly. The howling seems to be worse at cold startup and when the car is hot. No issue with temps, no leak from what i can see. I have 130k so im leaning towards a bad fan clutch.
  7. May 24, 2017 at 6:42 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    A locked up fan clutch (which is what it sounds like) is going to wipe out your water pump as well. At 130K, I'd put a pump on it too.
    As far as "power down greatly", it's unlikely the fan clutch will solve that, but you have to start somewhere.
  8. May 24, 2017 at 7:26 AM
    Razorecko
    Yea thats the plan. Water pump & fan clutch. Ive been losing a little bit of coolant over time so the water pump is probally burning off leaking coolant. I know the hg is good because the engine was rebuilt after the dealer nuked a piston ring when the fubard and put in stock +1 hotter oem plugs into the fi motor.
  9. May 24, 2017 at 10:33 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    What year truck and mileage? They dont last forever and until you replace it, you really dont realize how shot it is. Replaced mine with 140k on it, ac works better now and when you start the truck up you can hear that fan blowing air like crazy
  10. May 24, 2017 at 11:08 AM
    Razorecko
    i'm at 130k & mine is an 09. You replaced fan clutch, pump, or both ?
  11. Mar 7, 2019 at 5:29 PM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    @Jimmyh big thanks for your post above. Had grinding audible through tensioner pulley bolt (even though it was recently replaced), was changing out my water pump and had grease and dirt all up in the pulley. Ordered a new clutch fan based on what I read here. 2007 4runner with 133000 miles. Thanks guys.
    Jimmyh likes this.
  12. Mar 8, 2019 at 7:12 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup: always glad to hear my post helped.
  13. Sep 12, 2019 at 9:03 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Are there different fan clutches for the 4.0L V6? Mine is pink but have the towing package but I am not the 1st owner of this truck so...
  14. Sep 12, 2019 at 10:11 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The fan clutch will drag a bit on cold start -- spins the fan more, briefly. After cold start, the general operating principle would be:
    cold to warm = spins more freely because less cooling air is needed
    normal temp to hot = clutch grabs more so the fan pulls more air, but not completely locked
  15. Nov 24, 2019 at 1:24 PM
    TireFire
    Olympic Peninsula
    Looking online I see 2 part numbers for similarly priced fan clutches that fit my truck (4.0L V6):
    16210-0P010; and
    16210-31020
    What is the difference??
  16. Nov 25, 2019 at 3:01 PM
    TireFire
    Olympic Peninsula
    Bump
