Bad FM reception - can you help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SlappyDave, Aug 3, 2023.
  1. Aug 3, 2023 at 9:38 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the wire in the headliner may be part of the ant
  2. Aug 3, 2023 at 11:42 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Aw gesh, that’s embarrassing! The HD was going in and out whenever I moved the truck- will have to retake that!
    I use a Victory hood antenna mount now - passenger side next to the windshield. I slightly modified mine to fit over a ditch light mount also… they are simple but expensive, but supporting locals who are supporting Taco owners is a good thing too… anyway, look at this - it may give an idea as to how to maybe mount yours also.
    https://www.victory4x4.com/product/VT3CB-BARE.html
  3. Aug 3, 2023 at 11:56 PM
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Adding LED's anywhere can screw up FM reception. Not so much when they are new but as they age it can get worse and worse. The FM in my S10 drops down to almost nothing when one of my aftermarket LED headlights is burning out. The bad radio reception starts before the bulb actually goes dark.
  4. Aug 4, 2023 at 2:34 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That is true, other brands certainly do it too. I’ve only really ever bought stuff from Rigid, VLEDS, DD, and very little from others. The stuff from DD had enough issues that I sent most of it back, and the Max fogs I tried were the final drop in the bucket for that problem. The other two brands I have plenty of with never an issue on any trucks I’ve used them on, so I tend to stick to them. There are also people who do not have issues with DD, so mileage will vary of course.
    I do know when I had problems with DD, google brought up quite a few similar experiences across some Ford, Nissan, and Toyota forums. I was within the return period so it felt best to just get my $550 back and cut my losses.
    I have not noticed any problems starting as any of the rigid or VLEDS stuff gets older but I suppose we’ll see as time goes on.
  5. Aug 4, 2023 at 6:06 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    First off, if you want to listen to music or talk radio with any fidelity - do not use SiriusXM. Seriously. :bananadead:
    Many many FM stations also have a streaming counter-part which you should be able to get to via TuneIn, or Radio FM (on Android). There are counterparts on the Apple App Store. Stream the FM station or podcasts from one of these. You'll be glad you did.
    Bonus if you use Apple CarPlay or Android Auto. On AA, so easy to hit the mic button on the steering wheel and say something like "Play xxxx on TuneIn", or similar. Spotify, iHeart Radio, or Pandora are great alternatives. Listen to exactly what you want. :bananadance:
    Taco_mike73 likes this.
  6. Aug 4, 2023 at 6:53 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I thought I was the only one that thought the FM reception was a little weak in the Tacoma. Being in the Susquehanna Valley some of the various FM stations are spread out across Harrisburg, Lancaster and York with me being in York. The Harrisburg ones tend have some static as I drive around. About the only clear one is WSOX, the oldies station. No so bad because music I like is now considered oldies.
    I have Diode Dynamics fogs, interior LEDS and LED low beams. I know LED lights can cause problems with VHF tv reception at home from poorly made stuff that bleeds RF radiation. Makes sense that it could with FM too since FM radio is sandwiched between the low and high Vhf TV bands. cheap LED bulbs are often the cause of VHF TV reception issues.
    I think mine has never been good even before I installed the LED stuff.
    I feel like a good fender mounted whip antenna like vehicles used to have would fix that. Then that would disrupt the sleek lines designers want and they get broken in car washes.
    I mostly have stopped listening to FM and mostly favor playing stuff from my music collection of CDs and mp3 files that I have on my Plex server at home. The Plexamp app works great with AA and Apple car play. It's like my own streaming service with no subscription fee and music that I've collected over the years.
    stftaco likes this.
  7. Aug 4, 2023 at 6:58 AM
    BLtheP
    Plano, TX
    To be clear, I only had issues with DD stuff when they were on. As soon as I turned the fogs off, reception went back to normal. So problems when they’re off would indicate something else is the problem. If they’re on, there’s a good chance they are the problem.
    Irons likes this.
  8. Aug 4, 2023 at 7:16 AM
    Taco_mike73
    York, PA
    Right, I've experienced the issue even during the day with no headlights, fog lights or inside lights on. I just chalked it up to the newer more hidden antennas being less effective. I'm sure there's some more to it that I could dig in to. I'm not sure it's worth the effort since I mostly use my personal streaming thing and 3/4 of my driving is daytime.
    The thing with LEDs causing radio inference definitely is real. I've seen at home with TV reception. We had some cheap bulbs at home and when ever those were on I'd see breakups on a station using RF channel 8 to broadcast. Replaced the light with a better quality one and the issue disappeared. The same would happen to FM since those bands are close.
    Before this I thought DD was a good product too. They sure do have a nice light output.
    BLtheP[QUOTED] likes this.
  9. Aug 4, 2023 at 7:17 AM
    BLtheP
    Plano, TX
    Yeah, I had similar issues with Great Value LED bulbs in my garage opener making the garage door remotes no longer work if the bulbs were on. Had to go with garage door specific bulbs. Haven't had issues in the house with TV remotes but I also keep the inside lights off quite often.
    Taco_mike73[QUOTED] likes this.
  10. Aug 4, 2023 at 3:03 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Thats another option I've looked into as well (though indeed that is a bit rich for a simple little piece of aluminum, I'll probably drag out the plasma cutter to make my own). Haven't yet decided which way I'll go... Putting the FM antenna on the fender would look more "factory-like", but a hood mount like that certainly is simpler (as long as the grounding is good there anyway, maybe by use of braided ground straps if necessary).
    Appreciate the link.
