Bad fuel economy and slugging acceleration 2007 4.0l v6 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackson Fries, Aug 22, 2022.
  1. Aug 22, 2022 at 8:39 PM
    Jackson Fries
    Jackson Fries [OP] Active Member
    Hey fellow taco lovers. I'm looking for some insight into a problem I'm stumped on.
    I bought my truck 2 years ago with 316xxx on it blew the motor at 325xxx
    swapped a 2011 motor in and ever since then i've been getting about 250kms per tank compared to the 400-450 i used to get. The truck also has a very sluggish acceleration and feels like its "choking"/under very heavy load like towing.
    I have p0420 for bad cats, I bought it like this and it was fine.
    This problem goes away temporarily if I disconnect the battery for 15 or so minutes to reset the ECU, but the problem comes back after a few restarts of the engine.
    I have tried running seafoam through many times. I have cleaned the MAF, put a new air filter in new trans fluid and new plugs with no luck. Also new alternator last fall. seemed a little worse after I replaced that.
    Can anyone chime in on this?? I am completely lost I can also provide some videos of it chugging vs after I reset the codes tomorrow.
  2. Aug 22, 2022 at 8:41 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd want to check exhaust backpressure, I'm thinking you may have a plugged cat.
  3. Aug 23, 2022 at 6:03 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Sounds right to me, choked off it is.
  4. Aug 24, 2022 at 4:21 AM
    Jackson Fries
    I have check and the exhaust is clear no blockage. However it does still feel like it’s choking. And the problem completely goes away for the first start or two after disconnecting the battery for 15 or so. Could this be an AF MIX problem?
  5. Aug 24, 2022 at 4:27 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you sure P0420 is your only code?
    And can you tell us what you fuel trims are when this is happening?
  6. Aug 27, 2022 at 3:34 AM
    Junirol
    Junirol Well-Known Member
    Rolando
    San Diego California
    05 Tacoma Prerunner SR5, 10 Tacoma 4x4 Off road
    E85 Flex fuel, TRD CAI, Magnaflow exhaust, TRD Supercharger
    sounds like clogged cats, or the cats coming apart clogging somewhere in the exhaust system.
  7. Aug 27, 2022 at 4:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You can't quit ignoring the truck telling you it has an issue by temporarily erasing the code if it keeps coming back. You have failing cats that has been purring at you and now meowed for the last time. It's not going to cough up the fur ball this time.
    BlkDakDave likes this.
