Bad Fuel Pump or bad Fuel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by V30FtFall, Sep 20, 2022.
  1. Sep 20, 2022 at 10:33 AM
    V30FtFall
    V30FtFall [OP] Member
    Laci
    2017 Tacoma TRD 4x4 Manual
    Filled up my tank yesterday got about 15 miles my engine kept stalling when I was at a stop, would turn over okay (not like a starter issue) but it did this 5 times at consecutive red lights. The truck would restart but had to keep the engine RMP up to keep it from stalling. No check engine light or any lights came on but there was a little tap like feeling felt like it wanted to come out of first gear. It wasn't like stalling it out lol it was just a quiet no shake in stick ,truck stalled. This is my second manual tacoma first was 2008 never had anything like this before. If it's bad gas I don't want to run the rest of it through the engine so how do I get it out before going to the fuel pump or regulator? Any thoughts?
  2. Sep 20, 2022 at 11:31 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Doesn’t really sound like bad gas but stranger things have happened. 17’s weren’t part of the fuel pump recall but it could still have gone bad. Many auto parts stores have code readers so I’d try to see if your truck is showing a code before going to the dealership.
  3. Sep 20, 2022 at 11:45 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    You didn't by chance "top off" the tank did you? That is putting more gas in after the nozzle clicked off.
    It you did don't do that, it puts liquid fuel in the vapor recovery system and can lead to an expensive repair.
    zoo truck, whatstcp and Superdave1.0 like this.
  4. Sep 20, 2022 at 11:46 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    when you filled up did you force more gas in the tank buy click, click with the gas pump filler?
    that is a no no can cause what you described.
    whatstcp likes this.
  5. Sep 20, 2022 at 11:49 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Could be bad gas, or an issue with your EVAP system. Charcoal canister purge solenoid going bad will make it idle like shit/stall when the tank is full.
  6. Sep 20, 2022 at 12:01 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I would check for codes, some take multiple occurrences to set the light, but will show as pending with a code reader. Auto parts stores have free code reading.
    I wouldn't rule out anything, but I would start with bad gas as the most recent thing immediately proceeding the issue. I also note September 16th was the first day stations can sell winter fuel.
    Edit: Welcome to the forum!
  7. Sep 20, 2022 at 1:21 PM
    V30FtFall
    Laci
    The truck didn't give any codes I only put in half a tank. I'm going to try and drive it this afternoon to see if it will throw a code but concernedif it is bad gas putting more through my truck. I looked up recalls for my Vin and the only think that pulls up is a center high mounted stop lamp. The fuel pump recall is for 2018-2019
  8. Sep 20, 2022 at 1:23 PM
    V30FtFall
    Laci
    Thank you all for your thoughts and welcomes
    RustyGreen likes this.
  9. Sep 20, 2022 at 1:28 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Mine was. I believe later builds were included.
    OP, check your truck for the fuel pump recall: https://www.toyota.com/recall
  10. Sep 20, 2022 at 1:51 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Sound like bad gas.
    cryptolime likes this.
  11. Sep 20, 2022 at 1:55 PM
    V30FtFall
    Laci
    Oh thank you let me call dealer see what they say.
  12. Sep 20, 2022 at 1:57 PM
    V30FtFall
    Laci
    na8rboy if is it bad gas would it be bad to run the rest of the tank through the system?
  13. Sep 20, 2022 at 3:12 PM
    na8rboy
    WI
    Throw a bottle of iso heat red bottle in it, and or some seafoam. See how it reacts to that. It will pinpoint it down to bad gas, or something else.
    zoo truck likes this.
  14. Sep 20, 2022 at 3:13 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    My 2018 was recalled for the Fuel Pump and replaced by Toyota under recall. You may want to check on your 2017.
  15. Sep 20, 2022 at 3:59 PM
    Captqc
    Tigard, OR
    bulalo likes this.
  16. Sep 21, 2022 at 3:54 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    fill up the rest of the tank with good gas. if it's bad gas, the good gas should dilute it enough so you can burn the tank without stalling. it will probably still run pretty crappy though. could also be a clutch issue.
  17. Sep 21, 2022 at 6:09 PM
    Partyh
    Partyh Member
    Martin
    2017 Inferno TRD OR AT
    Isn't there a recall for that part
  18. Sep 21, 2022 at 6:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Could be diesel mix up from the gas station as well. I've seen it happen.
    17's are still prone to fuel pump failures outside of the recall. This doesnt sound like it.
  19. Sep 21, 2022 at 6:27 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    @V30FtFall What area are you in? Just get any rain? Possible the station had a water intrusion or something. I'd go talk to the station management. Might be others with similar complaints and you'll want to get in on the claim if there is one that happens.
    IF you have a bunch of space in the tank, consider filling from a quality station like Chevron or Shell and I would also dump a container of Startron Marine treatment into the tank. We use that for our boats where the possibility for fuel pulling water into the tanks. It allows it to break down into the gasoline and the engine can safely burn it. The product can be had at Walmart in the marine section or the automotive section or many auto parts stores.
    If you didn't get a code, you might need a higher level scan tool to pull codes for unlit warnings. Not sure if Autozone or similar has that level of scan tool.
  20. Sep 21, 2022 at 7:10 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    My old truck ran like that in Death Valley, after the battery shook itself to death on a washboard road.
