Bad Gas Mileage 4x2 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by billzyota, Feb 15, 2009.
  1. Feb 15, 2009 at 6:43 PM
    billzyota
    billzyota [OP] New Member
    Birmingham, Al.
    2018 Tacoma TRD Off Road
    I just bought this little 98 tacoma 4x2 with a 2.4L and automatic. it has 111k miles on it.
    The problem is that it is only getting about 16.5 mpg (city driving). i would have thought it would do better.
    It has been tuned up (new plugs and wires) with a fresh air filter. It runs ok for the most part. it seems like there is a little slow pulsing in the motor as it goes. hard to describe but it seems to rev and slow slightly as it's going at constant speed.
    i just cleaned the throttle body today and it seems to be running a little better.
    any suggestions or ideas would be appreciated.
  2. Feb 16, 2009 at 10:16 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Try disconnecting the battery and cleaning out the mass airflow sensor. I highly dought your front o2 sensor is going out. Some may say try sea foam.
  3. Feb 16, 2009 at 3:43 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    I heard the Z Max works really well too. Hows your Tired pressure?
  4. Feb 16, 2009 at 3:45 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    SeaFoam the beast. Might need a valve adjustment that that many miles... I get about 20mpg.
  5. Feb 16, 2009 at 4:25 PM
    billzyota
    Birmingham, Al.
    Tires are fine. i ran lucas fuel system cleaner through it when i bought it.
    the maf sensor didn't look too dirty but i could give that a try.
    has anyone used the crc stuff before?
  6. Feb 17, 2009 at 4:12 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Redline Fuel cleaner wil help.
    Put it ina tank that is from 1/4 to empty. then fill it with Chevron 89.
    Also do the battery disconnect thing.
    Also get the Computer scanned for stored codes.
    Add 5 to 10 PSI of air in the tires to make sure they are good.
    If the ride is to harsh then lower back to the dorr sticker.
    The truck has factory size tires right?
    The only time I go bad milage like that was when I was pullinga trailor and fully loaded to almost Max compaticy and driving up a 50 mile hill...
  7. Feb 17, 2009 at 6:53 PM
    billzyota
    Birmingham, Al.
    thanks for the tips. i will try to get the codes read.
    this is a factory two wheel drive tacoma.
    what kind of gas mileage do you get in yours?
  8. Aug 27, 2009 at 11:04 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    a new cap and rotor help a lot wen my truck did that
