Bad gas mileage!!! help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stubbs95tacoma, Jul 18, 2011.
  1. Jul 18, 2011 at 12:43 PM
    Stubbs95tacoma
    Stubbs95tacoma [OP] Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Alright i have a 95 3.4 liter tires are all at the same psi clean air filter oil is changed regularly only 95,000 miles and im getting on average 9.34 mpg this is nottt normal what do i need to do to get it back up?
  2. Jul 18, 2011 at 12:45 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    plugs, throttle body cleaning, fuel injector cleaner, and a lighter foot for starts
  3. Jul 18, 2011 at 12:48 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    ive had a light foot and new plugs last september
  4. Jul 18, 2011 at 12:49 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    grease your drive shaft, diff oils ok?
  5. Jul 18, 2011 at 12:51 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    ill add that to the check list.
    i think im going to take it in and get a new fuel filter and check out the o2 censor.
    Forgot to mention it dosnt have a cat someone stole it its a welded straight pipe no exaust leaks.
  6. Jul 18, 2011 at 12:52 PM
    elytravis
    elytravis Well-Known Member
    Travis
    Always changing...but there is no place like home.
    2012 Nautical Blue DCLB TRD Sport
    Black tube steps, Skid plate, Bilstein 6112's front and 5160's rear, Bakflip F1 folding cover, EGR raingaurds, All weather floor mats, AFE pro dry filter, BFG 265 70 R 17 KO2's.
    O2 sensor maybe
  7. Jul 18, 2011 at 12:53 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    ^ Probably an excellent next step (O2 and fuel filter)
  8. Jul 18, 2011 at 12:54 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Get rid of your straight pipes and go back to stock.
  9. Jul 18, 2011 at 12:56 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    its just straight pipe where the cat was still has the muffler on it
  10. Jul 18, 2011 at 12:56 PM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Dang, I feel good getting my 16-17 now!
    Clean MAF sensor, throttle body, 02 sensor, fuel injection cleaner.
    Do you have a check engine light on for the 02 sensor?
  11. Jul 18, 2011 at 12:58 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    nope no check engine light
  12. Jul 18, 2011 at 1:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How's it running? Under 10 mpg unloaded sounds like something is pretty off... Did this happen suddenly or gradually? Also, you sure on your math (not trying to be an ass, just starting with the easy stuff before you go tearing into your truck).
  13. Jul 18, 2011 at 1:24 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    I did the same a while back. Put a track pipe over the cats. Mpg went to shit.
  14. Jul 18, 2011 at 1:27 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    yeah ran it down to less than a gallon 5 times and averaged them out and i got the truck in september and the gas mileage was ok then it went down in december mainly because of the snow and 4wd i think and then went up in may to like 15 and then went to absolute shit.
  15. Jul 18, 2011 at 1:55 PM
    moto932
    Eric
    Dayton, Ohio
    04 TRD Off Road
    dont want to run you tank that low. it can damage your fuel pump
  16. Jul 18, 2011 at 2:04 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    x2 and i would think the cat is causing it.... shit idk
  17. Jul 18, 2011 at 3:11 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Not really, unless you run the tank dry and keep running the pump the pump will be fine.
    It's the fuel running through it that lubes and cools the pump.
  18. Jul 18, 2011 at 4:04 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    im going with a new fuel filter, r the spark plugs gapped correctly? theres an o2 sensor behind my cat, u may want to find a used cat if possible!
  19. Jun 8, 2014 at 7:36 PM
    austynstaco
    austynstaco Member
    Tucson Az
    95.5 Sr5 4x4
    K&N air filter glass pack muffler.
    O2 SENSOR I was getting a solid 9 mpg and worse took about 2-3 months for a code to pop up was the front o2 on mine same truck
  20. Jun 8, 2014 at 7:38 PM
    austynstaco
    austynstaco Member
    Tucson Az
    95.5 Sr5 4x4
    Check the o2 sensor I have the same truck with the same problem took like 3 months to trigger a code and until it did my mpg kept going down spent about 1100 on gas last month because of this
