Bad Gas Mileage Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Michaelow16, Jul 21, 2014.
  1. Jul 24, 2014 at 6:20 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Got a GPS?
  2. Jul 24, 2014 at 6:01 PM
    InfamousTonyTaco7714
    InfamousTonyTaco7714 Well-Known Member
    Lucas
    Wilkes, NC
    09 SR5 DCSB 4x4 Timberland Mica
    Borla Catback, 6 inch Pro Comp Stage 1 17x9 Matte Black XD Revolvers, 285/70/17 Radar Renegade R7, Pioneer Double Din, Iron Cross Side Steps, Tactical Armor Group Front Bumper, ARE MX series camper shell, Geared 4.10
    My speedo is off slightly. If i calculate my mileage based on my Trip it says i am getting in between 17.5 and 18 consistently. And i dont do much highway driving. I have a 3" spacer with 285's and my gas mileage didnt even go down enough to tell honestly. Drive light footed, thats what my problem was when i was younger, driving like a bat outta hell.
  3. Jul 24, 2014 at 6:26 PM
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    This guy is right. I have read online where there has been research done that has proven the worst time to fill your tank is when its hot outside. You have more gas evaporation during the transfer from pump to tank during the high heat. Also, not pumping it so fast helps slow the evaporation rate. There are numerous other tips but those are both very true.
  4. Jul 24, 2014 at 7:44 PM
    Overlander
    Overlander Well-Known Member
    33"s are about 10% larger than stock so you really are getting 253 miles out a tank.
    With 255/85/16 tires and a lift I get about 250-300 miles from a tank before odo correction. Stock intake with clean filter and air sensor. Tires properly inflated.
  5. Jul 24, 2014 at 7:44 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The longer the tank is open (during slow fill) the more evaporation "could" occur, but under already saturated gas vapor the fuel doesn't evaporate more.
    Virtually immeasurable gain, not 10%.
    But if you read it online........ :rolleyes:
  6. Jul 24, 2014 at 7:52 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    If you have a smart phone just download a GPS app that has mph read out on it.
    Works great on boats to see how fast you are actually going since the gauges are not that accurate at higher speeds.
  7. Jul 24, 2014 at 8:32 PM
    worthywads
    When you put it that way, it sure does sound absurd. :crazy:
    It's the nearly 2 gallons that evaporate while I add 18 gallons that hurts.
  8. Jul 24, 2014 at 9:03 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    And then there is the negative impact of ethanol...
