Bad gas mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by dmbrazilian, Oct 1, 2019.
  1. Oct 3, 2019 at 10:08 AM
    dmbrazilian
    dmbrazilian [OP] Member
    2002 Tacoma PreRunner SR5 4 door 2 wheel drive
    None
    Mojave, where did you get the charcoal canister?
  2. Oct 3, 2019 at 10:14 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    no
    it is the air fuel sensor in front of the cats (sensor 1) which totally affects how much the injectors spew
    jammer[QUOTED] likes this.
  3. Oct 24, 2019 at 3:48 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Find anything out? My trucks all of a sudden become really bad as well. Used up over a 1/4 tank of gas from Full and only driven 19 miles.
  4. Oct 24, 2019 at 4:21 PM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    Following.
    Mine is awful too. Im getting 12.5mpg. Plugs were replaced 15k ago by the dealer as well as the fuel filter and 3 ignition coils, used multiple fuel injector cleaners, cleaned MAF, got an alignment and it has remained the same. Check engine light works but is not illuminated. I'll have to check fuel trims
  5. Oct 24, 2019 at 4:36 PM
    dmbrazilian
    None
    Nothing, same thing. Only things left are the fuel injectors and the coil packs....not sure I wanna spend the money on that yet though.
    Am still interested where Mojave got the charcoal canister?
  6. Oct 24, 2019 at 4:52 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    For what it’s worth I switched the rear diff oil over to synthetic and the truck seems to roll better after you release the throttle. Maybe new shocks might help, too
  7. Oct 25, 2019 at 8:11 AM
    tacomainthesun
    tacomainthesun Well-Known Member
    02(sold) 17 trd or
    My v6 gets 19. Muffler delete,(for fun) new plugs, run no ethanol for a lil bit. If sluggish check out cats. Beyond that it gotta be motor components I guess.
  8. Oct 25, 2019 at 8:14 AM
    tacomainthesun
    02(sold) 17 trd or
    V8 swap for improved mileage:anonymous:
    nudavinci64 likes this.
  9. Oct 25, 2019 at 3:46 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    1/4 tank in 19 miles? You have a hole in your tank, lol
    Or your fuel sender is bad.
  10. Oct 25, 2019 at 4:23 PM
    tacomainthesun
    02(sold) 17 trd or
    My full sender works perfectly well on my truck!:devil::burnrubber:
  11. Oct 25, 2019 at 5:08 PM
    jbrandt
    Justin
  12. Oct 25, 2019 at 5:16 PM
    det107
    det107 Well-Known Member
    I bought mine at Rock Auto but it was for the 3rd gen 4Runner.
  13. Oct 25, 2019 at 6:13 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    You really need to get some fuel trim data. It could be a massive vacuum leak..
  14. Oct 25, 2019 at 6:18 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Amazon sells them too.
  15. Oct 25, 2019 at 6:52 PM
    #35
    dmbrazilian
    None
    What do you mean by fuel trim data?
    As far as a vacuum leak I should go to a shop that has smoke machine I'm guessing...
  16. Oct 25, 2019 at 8:33 PM
    #36
    jbrandt
    Justin
    Amazon also sells books and games, and as a horrible track record of car part fitment knowledge.
    Buy from an auto retailer.
    OneWheelPeel likes this.
  17. Oct 25, 2019 at 8:43 PM
    #37
    ArizonaBrian
    Fuel trims are the computers strategy for fuel delivery and is invaluable in diagnosing many issues.
    You can go to Walmart and get a scanner for $40 which will read live data stream. From there you could watch a video on how to diagnose using fuel trims. The fuel trims and O2 sensor data will tell you a lot even if the computer is not sending a code.
    cruiserguy likes this.
  18. Oct 25, 2019 at 8:48 PM
    #38
    dmbrazilian
    None
    Thank you Arizona
  19. Oct 25, 2019 at 8:52 PM
    #39
    ArizonaBrian
    But in the meantime if you wanted to check for a vacuum leak you could visually check the hoses and make sure everything is connected. Likewise you can get a spray bottle and start spraying the rubber hoses,around the intake manifold, etc.. & listen for a sucking sound.
  20. Oct 25, 2019 at 8:55 PM
    #40
    ArizonaBrian
    But it could be a lot of different things. I would like to see the MAF readings as well. Having your own scan tool will help others help you on the internet in addition to helping yourself.
