Bad hop coming from the rear!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cajun1, Nov 16, 2011.
  1. Nov 16, 2011 at 12:25 PM
    Cajun1
    Cajun1 [OP] Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    Ever since i bought my 05 Tacoma 2wd i've been having a very bad bouncing feeling in the rear...I have 265 Destinations on all four wheels and the two tires in the back are more worn than the other two in the front...I looked into why they were wearing like they are ( mostly in the middle and kind of spotty "hear and there")....I found out that it could be my shocks in the rear that are bad... i've got 80k miles....
    When i last got them balanced the shop said they couldnt really get them ballanced b/c the tire in the middle of the tread was hoping just like it does when i drive
    Is it the tires that are bad or the the shocks....or a combination of both?
    any advice?
  2. Nov 16, 2011 at 12:30 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  3. Nov 16, 2011 at 12:32 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Change out your rear shocks, sounds like they are toast. :eek: You might have to get new tires but I wouldn't think you should. Start with your shocks and go from there.
  4. Nov 16, 2011 at 12:37 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah new shocks like billy 5100s would work well and then since the wear on your tires is odd you might have to change those also but I had the same hop feeling and that was fixed with new shocks
  5. Nov 16, 2011 at 12:44 PM
    Cajun1
    Brooks
    Abbeville, LA
    billy 5100s= my best bet?? how much?
  6. Nov 16, 2011 at 12:49 PM
    Cajun1
    Brooks
    Abbeville, LA
    i see they are a racing shock....i dont need any of that...it there a differant alt. such as kyb?
  7. Nov 16, 2011 at 1:34 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    If you feel that replacement stock Toyota shocks would work for you and your driving, choose most any new shock. Bilistiens are a premium shock and offer a lifetime warranty if you think you will be keeping your truck a long time yet. If I recall, nonadjustable rear Bilstiens are running about $60 each. Napa replacement shocks are in the $45 range, plus installation.
    Front shock/struts for your truck will be more costly and you need a coil spring compressor to change them. Something you need to consider if you want to change them yourself. Do not try some homebuilt jury rig spring compressor.
  8. Nov 16, 2011 at 1:39 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Check tire pressure!!!!!!!! Appears to be OVERINFLATION--
    check ALL TIRES--When i purchased my truck--the right rear hopped--poor handling on curvy roads. ONE tire had TOO MUCH PRESSURE
  9. Nov 16, 2011 at 2:08 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Northern California
    2016 TRD Sport AC 4x4 Super White
    and poor traction
