Bad idea to tow long distance with 2.7?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Aug 8, 2013.
  1. Aug 8, 2013 at 8:28 AM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Have a 98 2.7, and am thinking about towing a 17' boat about 7 hours. Boat probably weighs about 2-2.5k lbs. This seem like a bad idea? Anything specific I should do to the truck before hand besides change the oil, (about due).
    I've towed tons with other trucks, just not sure if the little 2.7 is up to the challenge of long distance towing.
  2. Aug 8, 2013 at 8:40 AM
    medic2230
    Murph
    Bama! Roll Tide
    I hauled a 21' Chris Craft Cabin cruiser from Kansas City, Mo to Columbus, Ga with mine on a tandem trailer. Rained on me the entire time and the bilge had 6" of water in it the whole time. I didn't have any problems, even towed it over Monteagle in TN.
  3. Aug 8, 2013 at 8:45 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I've towed my 20' bass boat up to 5 hours no less than 20 trips, and never had an issue.
    Is yours an auto?
    Just make sure your receiver is tight, topped off coolant, brakes are good, and air pressure is good.
  4. Aug 8, 2013 at 9:06 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    you'll be fine. check all the normal stuff like JPP said.
    just watch your speed on the hills. Don't expect to be doing 75 up the hills.
    I was hitting 40-45 going over some spots with my 2004 V6, towing a 2500# popup trailer.
  5. Aug 9, 2013 at 7:13 AM
    irhunter
    irhunter Well-Known Member
    Maine
    '96 2WD 5-sp 2.4 Tacoma and '03 4WD AT 4.7 Tundra
    JPP asks the correct question: AT or manual tranny?
    If AT, consider adding a tranny fluid temp gauge.
  6. Aug 9, 2013 at 8:11 AM
    JUDG3
    JUDG3 Active Member
    Blake
    Florida
    05 PreRunner Super White
    265/75/16 Fierce Attitudes on MT Classic Locks, Black Badges, Secondary Air Filter Delete, AFE Pro Dry Filter, RevTek Lift, Magnaflow High Flow Cat and Muffler, Pioneer double din indash DVD head unit
    Ive towed my 13ft Whaler with full custom decks weighin bout the same (2-2.5k) from North GA Appalachian mountains to jacksonville, fl up and down all the mountain roads with no issues... but like said before dont expect much over 45 on the steep grades... some times not over 30 on real steep grades (2nd gear). I drive a 05 tho so idk if that makes a huge difference
  7. Aug 9, 2013 at 8:49 AM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    Should be able to handle it, as mentioned above. The only other concern I would have is due to the year, how good is the cooling system in your truck? Also, brakes and general maintenance of the truck.
  8. Aug 9, 2013 at 11:00 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    My 04 2.7 when i had it was a towing machine. I fish at least 30 hours a week all year round. So in the summer I tow one of my three boats, the heaviest being maybe 2k lbs, but in the winter I pull an enclosed 2 place trailer with two snowmobiles in it and the bed full of ice fishing gear. Trailer might be 2k lbs with the sleds. I once pulled it to Labrador which is a 17 hour drive. Like said, you won't passing many people on the uphills, but it will get there. If you are really worried about it, talk to your dealer or shop about a transmission cooler. The 2.7 even with a 4x4 doesn't come with one. I never had one and the auto tranny was still working great at 220k miles when I sold it. I would eat through brakes though, like 25k miles and the pads and rotors were spent no matter how high end I bought.
